Need some help with my tune
Alright so basically as the title states, im in need of help with my hp tune lol my car bogs from first to second pretty much every time. Im thinking my airflow tables are totally screwed up and im planing on taking a road trip with my car so im in need of a steady good tune that'll be perfect for a daily driven car. I can post up all my mods and logs if someone can help me get a good tune. Also while in idle my air/fuel is not steady. it bounces from 14.6-15.4 constantly, is there a way to fix this problem? Thanks and sorry for the newby problems on tuning lol
My Car does excatly the same thing the only way You can fix this to get accurate reading is this. Here's the Link. https://www.cobaltss.net/forums/how-...ctures-275518/
This is the only way to solve Your Problems.
Can anyone look at my logs and help?
i posted my logs and tune that im using on the hptuners forums. If anyone would like to look over my logs its in the link above.
your afr will not sit at 14.7 at all times.....it will fluctuate slightly due to the ecm always compensating from the fuel trims.
as for your pe table......set the pe table at a constant value and see if you can get it in line that way.
I looked at your tune on the hp forum, but I don't know what config you are using, so a lot of the info wasn't showing up on the logs.
