Need Torque specs for everything head on up
Old Feb 4, 2008 | 10:26 PM
MadboostSS's Avatar
changing my head gasket tomorrow so need specs for everything under the valve cover
Old Feb 5, 2008 | 09:26 AM
MadboostSS's Avatar
bump anyone????
Old Feb 5, 2008 | 09:29 AM
njg5gt's Avatar
get a haynes manual? sorry i don't ahve one
Old Feb 5, 2008 | 09:35 AM
D4u2s0t's Avatar
the valve cover bolts are 71 ft/lbs. Not sure what else you need other than that.
Old Feb 5, 2008 | 09:43 AM
bigjoe25's Avatar
the head bolts 22ftlb first pass than turn 155 degrees check the link it has all the info
http://www.gmperformancedivision.com...SJ_Chap5&6.pdf
Old Feb 5, 2008 | 11:35 AM
burntorange's Avatar
too much
um....71 seems too much for valve cover bolts..... it should be more like tenish.....
hope you weren't serious.....
Old Feb 5, 2008 | 11:50 AM
D4u2s0t's Avatar
nope, i was 100% serious took it right out of my haynes manual. I thought it was a little high too, bu a lot of the bolts in the engine have pretty high torqe specs.
Old Feb 5, 2008 | 12:57 PM
2K5SS/SC?'s Avatar
I can't find them on the site yet, but I know they're on here somewhere. Do yourself a favor and go to the dealership and ask for a complete car torque specs printout. I have one at home and use it all the time.
On a side note, just some words of advice. I hope you are planning to resurface the cylinder head, are buying new headstuds and not using headbolts again, as well as getting a nice headgasket preferebly a Cometic one. If you don't have the head resurfaced at a machine shop, the gasket won't seat properly and it'll blow again. You cannot reuse the head bolts as they are torque-to-yield i.e. you can only use them once, and using another set of them is dumb anyhow when you can get headstuds instead. I'm just trying to give you a heads up here coming from someone that has done this already. Oh, and make sure you double and tripple check the timing upon reassembly so you don't destroy the engine. If you have any questions feel free to ask, but other than that good luck.
Hey, here is the link to the informational sticky I made on a headgasket install. The only thing new is that you can order a 2.0L headgasket from Cometic now instead of a 2.2L one.
There is a link for the torque specs thread inside of it. I told you it was on here!
Old Feb 5, 2008 | 04:12 PM
sunfirejoe's Avatar
are u sure it was 71 inch pounds, cuz a lot of this motor is done in inch pounds
Old Feb 5, 2008 | 04:20 PM
D4u2s0t's Avatar
nope. that's what i thought at first too, i though 71 was high. but 100% the book says ft/lbs.
Old Feb 5, 2008 | 06:00 PM
ptrblkz24's Avatar
Damn man,you want him to strip the threads huh?lol.Your right about the 71 part,but its
71 lb/in
Old Feb 5, 2008 | 06:03 PM
D4u2s0t's Avatar
71 inch pounds is less than 6 foot pounds. that sounds crazy low to me, that's pretty much hand tight.
i'm just going by what's in the book.
Old Feb 5, 2008 | 08:50 PM
bigjoe25's Avatar
the gm power book says 10FTLB on the valve cover i would go with that
Old Feb 5, 2008 | 08:57 PM
sunfirejoe's Avatar
yah i remember doing mine and it wasnt 71 ftlbs lol
Old Feb 5, 2008 | 09:28 PM
MadboostSS's Avatar
Jw but how hard is it to take off the head and everything up and put all of it back in place?
Old Feb 5, 2008 | 09:31 PM
sunfirejoe's Avatar
biggest thing for the head gasket is getting the timing perfect afterwards
Old Feb 5, 2008 | 09:34 PM
Sunburst_SS's Avatar
well, if you know what you're doing it's fairly easy. I could have it done in a day easy. Sounds like you don't know much about working on cars, so I hope you have someone with some experience helping you. A cylinder head is a big job for a novice and there is lots of room to make expensive mistakes. Setting timing is very important. I've done a few cylidner heads on cobalts at work and they're pretty straight forward.
Old Feb 5, 2008 | 09:37 PM
bigjoe25's Avatar
look at the link i put up it well tell you all you need to know
Old Feb 5, 2008 | 10:03 PM
D4u2s0t's Avatar
just double checked. for the 2.0 engine it does in fact say 71 ft pounds. for the 2.2 and 2.4 though it does say 89 inch pounds, which works out to be like 10 ft/lbs or so.
Old Feb 5, 2008 | 10:04 PM
bigjoe25's Avatar
thats what i said 10 ftlb
Old Feb 5, 2008 | 10:05 PM
if you actually try and tighten them to 71 ft/lbs you might as well buy new bolts....and have a drill and easy out handy because you will snap everyone of them.....
Install the cover on the cylinder head and hand start the bolts.
Tighten
Tighten the camshaft cover bolts to 8 Nˇm (71 lb in).
straight from Dealerworld
D4u2s0t's Avatar
weird, i guess the book is wrong.
Old Feb 5, 2008 | 10:40 PM
bigjoe25's Avatar
ok but the gm 300hp build book says 10ftlb thats all i was saying
Old Feb 5, 2008 | 10:43 PM
D4u2s0t's Avatar
i get that we all just keep saying the same thing over and over. i think that 10 ft lbs sounds MUCH more reasonable than 71.
Old Feb 5, 2008 | 11:54 PM
2K5SS/SC?'s Avatar
Most of the stuff on the engine is in.lbs. Only the main things like the headbolts, rods bolts, etc are the only things that require heavy torqing. If you are using headstuds, follow the stud manufacturer's instructions instead of the factory ones for torqing.
Here is the link for all the torque specs since the original one I posted didn't show up:
https://www.cobaltss.net/forums/show...t=torque+specs
Here is the link to the headstuds and gasket ordering sticky I made:
https://www.cobaltss.net/forums/show...showthread.php
Here is the link to show you what you're getting into MadBoostSS:
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
Sep 28, 2015 12:51 PM
