New cams installed
ok this may sound dumb but im new at this cam stuff so what kind of timing do you need to do with the 272 or 280 i mean would you have to put the chain on tooth ahead or would you keep everything as stock or wouldnt you want ajustable timing gears to get the most out of them also what need to be done to the head to run the cams.
If you take too much out of the base circle the lash adjuster will not have enouch adjustment to ride smoothly on the surface of the lobe. However, if they add weld during the process they can still alter the cam specs without grinding too much of the base circle away.
Wop
If you're getting custom stem length, that's fine. Problems for stock valves though as there's only about 1mm (0.039") of preload on the stock lash adjusters.Welding the lobes first allows you to change the lift profile while keeping the stock base circle, minimizing changes to the geometery.
Wop
Wop
Blown4banger: The way you're doing it is good. Do what you do.
In other words, your stock lash adjusters will then be able to operate within their range. Another solution is to use modified mechanical adjusters, but it's cheaper to go ahead and get the add weld cam grind.
That Crane guy must be wrong
Hey Witt so where these "welded up" regrinds? or do you now have an altered (reduced) base circle. There's only 2mm total travel in the Ecotec lifter(aka fixed lash adjuster). IIRC stock is -1.0mm lash (preload) so you dont have much room to work with. Where's your base circle at?? They noisy??
Wop
Wop
They were noisy for the first day and have returned to stock noise levels since.
Dan is coming back into town Thursday and I'll measure his cams vs. my stockers and have exact numbers for ya.
LSA = Lobe seperation angle
. A wider LSA will result in a more tractor like, smooth and even torque curve that is broad. A tighter LSA will have a torque curve that targets a specific RPM. Yes the power will drop off after you have passed the engine speed in which the cam was ground for.
A wider LSA will give you better idle and low speed torque. That's not the part of the power band we are concerned with here. This isn't tractors to plow with.
Edit: Blown4banger never said anything about peak torque; he said that the tighter/lower seperation angle will shift your powerband higher. It will cause you to produce less peak torque with the tighter LSA but the torque will build quickly therefore doing more work over the amount of time alotted.
Here is the quote:
"Yeah, and the lobe seperation angle also determines where the power band is. The higher the seperation angle, the lower rpm the power band will be in, and vic versa. A 107.5 degree lobe seperation angle (like mine) will probably have trouble idling below 1200 rpm, and will make power into the 8000 rpm range. Thats why if you look at any cam catalog almost all the cams specified as a "street" grind, have a 110 degree or higher seperation angle."
The effect of larger and smaller LSA is on the power band what I am questioning. The upper half of the torque curve ( Y scale )defines the power band. A low LSA will produce peak torque at a lower RPM for a given camshaft specification. Torque at the top will also fall off at a lower RPM thereby giving less "top end" horsepower. This is shifting the powerband lower not higher. There is no free lunch.
I you are still having trouble understanding the concept I'd be happy to dig up a few more links for you to read.
Pierre
Yeah, the head is one of the most efficient stock heads EVER. The extremely high lift on the cam is what allows it to make power in the upper rpm, the head is what makes all the power, the cam kills power on that motor. Thats why if you look at a dyno chart of a stock LS7, it makes peak power at 6300 (because of the insanly good head) then dies, power drops steeply after 6400 rpm. Its another reason why a decent cam, and a tune yeild over 100 hp gain on the LS7.
Here is the quote:
Pierre
Here is the quote:
Pierre
Here i'll give you an appetizer; it's from http://www.chevyhiperformance.com/te..._lobe_phasing/:
Lower or tighter LSAs do make for a more narrow powerband and torque peaks quickly (not a lower rpm, it just peaks in a smaller range instead of over the whole RPM range) but it does not shift the powerband lower, sorry.
"The difficulty with overlap is that the results change with different engine speeds. Since race engines tend to operate in relatively narrow rpm bands (e.g., 5,000 to 7,500 rpm), it’s easier to design a cam to work in this rpm band. A street engine is a greater challenge because it must operate through a rpm band of 5,000 rpm or more (1,000 to 6,000 rpm). The key to making overlap work is maximizing the power in the rpm band where you want it. Long overlap periods work best for high-rpm power."
I'm sorry you're wrong. If you want I can provide multiple links that say opposite of what you are saying. Or if you'd like I can show you a dyno chart to prove it.
Lower or tighter LSAs do make for a more narrow powerband and torque peaks quickly, but it does not shift the powerband lower, sorry.
A longer overlap period DOES NOT MEAN A HIGHER NUMBER! The lower the LSA, the longer the overlap period.
The reason for the longer overlap period, is since both sets of valves are open at the same time, compression is lost at lower rpm, but at higher rpm since the pistons are moving so much faster, not as much compression is lost. It allows for maximum intake, and exhaust flow at high rpm.
Pierre
Pierre
Hmmm....those are very contradictory haha. Wider LSA is a higher number (Less overlap). A low LSA is more overlap.
Exactly, that's where he is confused. Higher LSA, shorter overlap; Lower LSA, longer overlap.
Increase Cam Duration (i.e. How Long the Valve is Open): Moves or shifts the peak torque and peak hp location to a higher rpm. The absolute peak torque and peak hp number also increases.
Increase Cam Lift (i.e. How Much the Valve Lifts Off or Opens From Its Seat.):
Higher lift gives a higher absolute peak torque and peak hp number
Tighten Lobe Separation Angle (Increase Cam Overlap):
Gives more peak hp but less low end torque.
Lobe Separation Angle (LSA) Definition:
This is the angle between the intake and exhaust camshaft lobe peaks described in camshaft degrees. This angle dictates two important events: the valve overlap around TDC and how much intake or exhaust valve closure delay there is
Tightening the lobe separation angle (making the LSA value smaller)produces more overlap around TDC. Widening the lobe separation angle (making the LSA value bigger) results in less overlap.
Overlap Definition:
The amount of time, expressed in crankshaft degrees, that describes the window of time between the the Intake Cam's opening point BTDC and the Exhaust Cam's closing point ATDC (i.e. the brief time when both intake & exhaust valves are partially open simultaneously).
Increasing the degrees of overlap tends to move the powerband up the RPM range. Increasing the overlap can increase peak power, but only if the exhaust system is properly designed and sized to scavenge the cylinder. Decreasing the overlap tends to improve lower rpm range performance.
Overlap can be increased in 2 ways independently:
- Increasing the Duration of the Cam (without changing the LSA)
- Reducing or Tightening the LSA (without changing the Duration)
hi, send pizza
Overlap Definition:
hi, send pizza
Overlap Definition:
hi, send pizza
Overlap Definition:
hi, send pizza
Overlap Definition:
hi, send pizza
Overlap Definition:
hi, send pizza
lol.
