New cams installed
I'm sorry you're wrong. If you want I can provide multiple links that say opposite of what you are saying. Or if you'd like I can show you a dyno chart to prove it.
Here i'll give you an appetizer; it's from http://www.chevyhiperformance.com/te..._lobe_phasing/:
I'll start http://www.webcamshafts.com/pages/cam_glossary.html Bottom of the page.
Thanks
Edit: Blown4banger never said anything about peak torque; he said that the tighter/lower seperation angle will shift your powerband higher. It will cause you to produce less peak torque with the tighter LSA but the torque will build quickly therefore doing more work over the amount of time alotted.
Look at the "varying lobe seperation angle". It says just like the one you posted that the tighter LSA will move peak torque to a lower rpm. You know that means it can make more power up high right? There will be more force applied at the right moment which will allow MORE WORK TO BE DONE OVER THE TIME ALOTTED (More power). I will post before and after cam dyno's to show you visually.
Edit: The faster torque can build the more force it can apply over a given amount of time. The higher the rpm goes the more power will be made with the quick rising and increased peak torque.
This is pointless to keep argueing. The people who know what they are talking about... well know what they're talking about. It doesn't matter what other people say, fact is fact. We don't need to prove anything here.
You're right. I will admit I was wrong about the peak torque numbers. I was thinking about it in the wrong way trying to prove my point. It's easy to see, if you install a cam (A recommended grind from a reputable company such as comp) with a tighter LSA you gain both torque and horsepower, I know this, it was dumb of me to say otherwise.
Edit: Pierre let's just drop this. If you have actually installed a cam on an engine before you would be able to understand where we are coming from. I promise you are just misinterpreting what has been said. I am not saying in any way that the websites you are using as your sources are wrong.
YOU'RE OUT OF MAXIMUM PWNAGE!!!
You seem to know quite a bit. Are you saying that I am wrong about the peak torque? I shouldn't have said what I did there and knew better. As far as everything else, I have seen it dyno proven after installing cams on many cars.
Anyways, here's an example. There are more mods than just a camshaft, but you can see the change in the powerband. You can see that as the torque peaked it created more horsepower.:
[IMG]
[/IMG]
Why would you think I've never installed a cam before? I was active for years in Nascar modifieds up here in New England and have put in dozens. And yes I'm perfectly comfortable degreing them in.
Unless you only change 1 thing at a time it's hardly a fair comparison. Can you be more specific about what the baseline was and what changes were made?
I'm OK with droping it although I think it's a very interesting subject. I generaly avoid pissing contests as they serve no purpose. There does seem to be a fair amount of conflicting information on this subject and I'd like to look into it a little more carefully.
That Crane guy must be wrong
Hey Witt so where these "welded up" regrinds? or do you now have an altered (reduced) base circle. There's only 2mm total travel in the Ecotec lifter(aka fixed lash adjuster). IIRC stock is -1.0mm lash (preload) so you dont have much room to work with. Where's your base circle at?? They noisy??
Wop
Wop
Add in a rough figure of rocker ratio from roller to contact point of the lifter and it should be in the neighborhood of 1.40 total mm additional lash the lifter has to take up, at least somewhere in that neighborhood.
Do you have any before and after dyno results for these cams? I, like Edubs, have the JBP cams and have had nothing but problems thus far and may consider switching them out if they truely make good power.
Ok, measured Dan's cams (the same as mine) to my stockers. The radius change at the greatest point was .80mm and that was on the exhaust cam. The greatest change in radius of the base circle on the intake was only .55mm.
i agree..... guys you all seem like some pretty cool folks but please know the pierre does this kind of stuff for a living. 99.9% of the time he wouldnt lead ya in the wrong direction.
this means you need those shims and were trying to get them to you ASAP. sinister is working on it as we speak. im kinda useless right now since im in the middle of the ocean.
When you break it down really simply you have more overlap and therefore a longer period of time for the exhaust to exit the cylinder and help to pull in more intake to fill the cylinder at engine speeds where without overlap it is not possible. Check out Holley's explanations, it's very cut and dry.
What does it do?
At high engine speeds, overlap allows the rush of exhaust gasses out the exhaust valve to help pull the
fresh air/fuel mixture into the cylinder through the intake valve. Increased engine speed enhances the
effect. Increasing overlap increases top-end power and reduces low-speed power and idle quality.
http://www.holley.com/data/TechServi...0Camshafts.pdf
Edit: Another thing is that a cam with alot of overlap allows exhaust gas reversion at low engine speeds. This has the effect of EGR and does not help power. But when you increase the rpm significantly the exhaust gas speeds up to the point of putting a vacuum on the intake port when the intake valve opens during overlap. This cause a burst in power, which increases with engine speed naturally.
I'm listening to him, but I think there's some sort of misunderstanding.
Here is some interesting info that ties my views together nicely and yes I'm quoting articals that support my view :-)
"Narrowing the lobe separation angle effectively advances the intake-valve closing point, allowing the cylinders more time to build compression as the piston rises to TDC. After regrinding the 02 LS6 lobes onto a 112 LSA (about 5.5 degrees narrower than stock) and installing the cam with a 107-degree intake centerline, Katechs modified LS6 cam doubles the overlap area. Narrower LSAs also tend to move the horsepower and torque peaks closer together. In theory, narrowing the LSA without altering the duration of the cam should improve low-end torque due to improved cylinder filling, moving the horsepower peak closer to the torque peak as a result of closing the intake valve sooner. Both predictions came true when we saw torque jump 13 lb-ft to 472 lb-ft at 4,800 after the cam swap with a corresponding 400-rpm drop in the horsepower peak to 466 hp at 5,600 rpm."
Taken from...http://www.hotrod.com/techarticles/1.../cam_swap.html
Pierre
"Narrowing the lobe separation angle effectively advances the intake-valve closing point, allowing the cylinders more time to build compression as the piston rises to TDC. After regrinding the ’02 LS6 lobes onto a 112 LSA (about 5.5 degrees narrower than stock) and installing the cam with a 107-degree intake centerline, Katech’s modified LS6 cam doubles the overlap area. Narrower LSAs also tend to move the horsepower and torque peaks closer together. In theory, narrowing the LSA without altering the duration of the cam should improve low-end torque due to improved cylinder filling, moving the horsepower peak closer to the torque peak as a result of closing the intake valve sooner. Both predictions came true when we saw torque jump 13 lb-ft to 472 lb-ft at 4,800 after the cam swap with a corresponding 400-rpm drop in the horsepower peak to 466 hp at 5,600 rpm."
Pierre
Pierre
Even still, I have a question; the question is not based on doubting your find but more out of curiousity. Although his HP peak shifted downward, was his cam still able to support power in the upper rpm range? Just wondering.
Good, I'm glad we figured this out. No one was right or wrong here and good information was provided to show both sides of the story.
Edit: In essence what I see from your article is that there is a way to run increased overlap without sacrificing low end power. They accomplished this by using a different intake centerline. That's cool, I never thought about it this way.
At this point we aren't arguing we're just discussing. I see where he's coming from now, but all in all if you buy a "canned cam" with increased overlap and install it straight up it will shift the powerband upwards.
You still are
Ok, i'll buy that actually. But, remember you can increase overlap using two different techniques. One technique is by increasing overlap without changing duration like your post demonstrates; the other technique is to change the duration of the cam. This is probably where we are having opposing views here.
Looking at the dyno sheets there was only a loss of 8-9 horsepower between 6,000 and 6400 and a solid 15-20+ ft #'s of torque in the low/mids for the 112 LSA grind. Good trade off I would say.
Pierre
My basic arguement was for a, given duration and lift, cam making the LSA narrower would increse low/mid end and decrease top end. It's a given that increasing duration, keeping the same LSA, will move the power band upwards. I have absolutly no argument with that and never have.
Pierre
Pierre
