New cams installed
Old Jun 28, 2007 | 02:50 PM
  #151
MVP's Avatar
MVP
Originally Posted by 06blackg85ss
I know I actually spoke to him a few months ago to get my head ported, before it disappeared for 5 months
Yeah Dave told me that he spoke with you over the phone. He asked me if I knew Paul with a cobalt SS I said the only one I know with a balt SS is a guy out of NY and his first name is paul so it must have been you.
Originally Posted by Witt
You can't use Ferrea's seat locators. It ends up with too high of a spring pressure for the hydraulic lash adjusters iirc.
I think sinisterredlines (Chris Henry) was running them with out issues. im not 100% sure though you would have to ask him.
Old Jun 28, 2007 | 03:58 PM
  #152
06blackg85ss's Avatar
yeah, I was trying to get it out to him, but someone wanted to digitally measure the head to make a cnc version, but never did a damn thing with it. But I will; be sending mine to him shortly
Old Jun 28, 2007 | 05:39 PM
  #153
MVP's Avatar
MVP
I'm going to send another head to him and have him put bigger valves in it this time and go even more wild on the porting. I tired to take pics of the porting work he did to my head for you guys but the camer was NOT playing along. its truly a work of art you guys would be most impressed im sure of it. the dude is bad ass plain and simple.(though about having it converted to the JESSLE valve train that GM used in thier DRAG balt but I dont know well see how much of a damper it will put on the checking account. )
Old Jun 28, 2007 | 05:45 PM
  #154
Witt's Avatar
^^Gimme an update on your build Mike. You get your clutch issue figured out?
Old Jun 28, 2007 | 05:53 PM
  #155
MVP's Avatar
MVP
Well im out to sea right now but Dave has a friend who is going to weld the 8bolt hole pattern shut and re drill it for the LE5 6 bolt pattern. my other option is to go to spec and they will make me a clutch = to that of the Exedy hyper setup with a custom flywheel to fit my crankshaft flange but they want me to buy 10 flywheels @ 350 bucks a pop just for them to fire up the CNC machines. my math isnt perfect but thats almost more then I've spent on my entire engine. Like I said though Dave is going to hook it up for me. He hasnt done me wrong yet. R&D is also going to help with all of my Turbo pluming Ect. for the snail conversion. I though briefly about twincharging but I think with the turbo and a bit of juice ill be ok. after I get the engine back together ill be running my blower for now with a 2.6 pulley I'm going to LA to a very well known tuning shop to have them fine tune this bad boy with the juice. ill bump the rev limiter up to 7500 and start the nitrous at 3000 cut the nitrous off at 7K
Old Jul 21, 2007 | 02:46 PM
  #156
shawns94's Avatar
Any numbers on the cams yet?
Old Aug 10, 2007 | 12:52 PM
  #157
firestorm's Avatar
Man, I Want So Many Toys, I Smell A Divorce Soon....
Old Aug 10, 2007 | 12:54 PM
  #158
Edubs's Avatar
Hey Witt, you sitting on your thumb? When are you hoppin' on a dyno?
Can't wait to see what a properly cammed car can do...
Old Aug 10, 2007 | 03:21 PM
  #159
firestorm's Avatar
HAS THIS QUESTION BEEN ASKED>
the gmpp race head. is that the goal here? or is it not compatable with sotck block?
it sells for 1100 bux.
Old Aug 10, 2007 | 06:57 PM
  #160
Witt's Avatar
Probably not anytime soon. I've been busy with other projects (turbo 2.4, now a local turbo redline broke a timing chain tensioner so starting the rebuild on that car) and haven't been able to do a thing to my own car other than order a pair of slicks that are sitting in my basement. Coupled with the fact I'm only home 3 days a week because I'm on the road working for the railroad its been a shitty summer trying to get anything done.
AlphaJaguar over on the redline forums is running the same setup, I think he's going to end up beating me to the dyno. I hope to have it on the track though in the next week or two, just waiting on a set of axles to arrive.
Old Aug 10, 2007 | 07:03 PM
  #161
nice man, my car is finally going in to get the turbo done this week. Depending on my bonus check this week, I should have my head and cams finally sent out next week at some point. Finally things are going to get done, oh yeah, picking up another monte SS this week to use my 406 sbc and T-76 on.
Old Aug 10, 2007 | 07:29 PM
  #162
Area47's Avatar
Rent me! per hour
i want pics!~!~
Old Aug 10, 2007 | 07:36 PM
  #163
there will be plenty
Old Aug 10, 2007 | 07:37 PM
  #164
Area47's Avatar
Rent me! per hour
you're worse then a woman
damn tease!
Old Aug 10, 2007 | 10:43 PM
  #165
Edubs's Avatar
Cool, thanks for the update. Best of luck at the track and let us know how you make out...
Old Aug 10, 2007 | 10:51 PM
  #166
g5mike's Avatar
Wow been awhile since the ol cam crowd got together again! hows everyones naughtly little cams??
Old Aug 11, 2007 | 04:42 AM
  #167
Witt's Avatar
Mine are screaming. I run a 2.8" blower pulley to an 8k redline and don't have much trouble putting a couple lengths on the 2.5/2.6" guys and a certain auto LS2. I'd say it was a success.
Old Aug 11, 2007 | 07:47 AM
  #168
g5mike's Avatar
I'm just starting to put my rebel m62 kit together,can I expect any bumps along he due to the cams? or shoulf HPT take care of that?
Old Aug 11, 2007 | 12:38 PM
  #169
Z Speed's Avatar
So how much do these cams actually cost for 272 specs???? once I get to my engine internals Im gonna buy it all at once and do a complete rebuild and get it all out of the way at once
Old Aug 11, 2007 | 06:26 PM
  #170
Edubs's Avatar
Mine are actually doing quite well. It was finally tuned a few months ago and I've gone through a few thousand miles w/ no issues at all. I put down 244/228 on a Mustang with these cams and a 2.8. I/H/DP/Stock Exhaust. I'm going back in September to have it tuned again for the upcoming cold weather, but before we mess around w/ it, I'll see if we can do a pull or two when the temp isn't 85 and the humidity is below 50%. I was hoping for 250/230 mustang. I'm sure on a good day my car can pull that off.
Old Aug 12, 2007 | 12:53 AM
  #171
spaz's Avatar
$250 plus shipping. They regrind yours and include the shims for under the lash adjusters.
Old Aug 12, 2007 | 09:52 PM
  #172
Witt's Avatar
I was curious myself as to what he is charging.
When I bought mine, I went through a 3rd party (namely MVP) and had to purchase his set of cams so I wasn't sure what the exact charge for only the regrinds and the shims would be. The total I paid was including the extra set of cams to be regound.
On a side note, these same profile cams are going to be installed in a turbo swapped LSJ this week. I can't wait to see what they do for performance. He has a dyno from before the cams, the only problem was a broken timing chain tensioner was playing with the tune since the stock cams were never in the same position with each revolution because of timing chain slack.
Old Sep 4, 2007 | 12:37 AM
  #173
ralliartist's Avatar
who do we go through to get the regrind, email? phone?
Old Sep 4, 2007 | 06:41 AM
  #174
g5mike's Avatar
www.jbodyperformance.com
Old Sep 4, 2007 | 08:21 AM
  #175
spaz's Avatar
I am selling a set of these cams.
https://www.cobaltss.net/forums/canadian-mid-west-112/some-parts-sale-locally-74538/
They came from Dave Endrigo at flowtecnic.
