new clutch engages early
Old Dec 7, 2011 | 08:06 PM
AngelTiger82's Avatar
So I don't know if its just me or somethings up. I just picked up my 06 ss/sc from the shop it just had the lsj upgrade clutch kit installed. I had the act kit andlightweight flywheel before, it used to take a good amount of force to hold the clutch. Now as soon as I start letting go of the clutch it engages, do I need my pedal adjusted or clutch bleed or is that just how the upgrade kit is. Or maybe I just need to get used to it.
Old Dec 9, 2011 | 07:20 AM
MyOtherSS's Avatar
ZZP sells an clutch adjustment rod, might want to look into that.
ZZPerformance - Adjustable Clutch Rod for Cobalt #02-02-00159
Old Dec 9, 2011 | 08:52 AM
BLAZIN07SS's Avatar
I'm too JDM for you
that's how the gmpp clutch is. starts engaging right off the floor
Old Dec 9, 2011 | 09:20 AM
mrbelvedere's Avatar
it will come up some after a while
Old Dec 9, 2011 | 10:25 PM
Sharkey's Avatar
mine did the same thing, i beld it a bunch and got no more air out and it grabbed quite low. after about 2 weeks of driving it started getting higher, it grabs mid height now, right where it should.
refrain from putting in an adjustable pushrod, its not needed. i run into problems at my shop with people who think they know what they are doing and adjust the master cylinder pushrod right after ive put a new clutch in. what happens is some air may be trapped and work its way out, the clutch has to break in, etc, and if the pushrod on the master cyl is too tight when all this happens is it will take up the pedal freeplay and it starts holding the clutch just like if you were riding it. this will lead to slipping and premature clutch failure.
Old Feb 8, 2012 | 02:56 PM
thanks I wanted to know the experiences of other people with the gmpp clutch. Its doing better, i got used to it
Old Feb 9, 2012 | 03:09 PM
SaberD's Avatar
i have the gmpp clutch kit and dont have this issue. if you have to push the pedal too far down to disengage the clutch, that usually means it needs to be bled.
What all was included in your kit?
when bleeding anything, a lot of people make the mistake of closing the bleed screw AFTER the pedal is down. This is not how it should be done, and can result in getting air in your lines. you need to make sure that for the last few pumps, the bleed screw is closed WHILE the pedal is being pushed down.
Old Feb 25, 2012 | 08:31 PM
Sully20's Avatar
Yeah, I just Installed my GMPP Clutch and it Grabs like right off the floor and I was wondering if it was normal and if it would come up some after the break in period, It was just installed yesterday.
Old Feb 25, 2012 | 09:27 PM
YelCal7's Avatar
Yep! Same goes for me start right off the floor, I was shocked at the same time love it!
Old Feb 26, 2012 | 01:21 AM
scoobydoobie's Avatar
Mine has been in over a year and never came up any from where it was when I picked it up from the dealer after the install.
Old Feb 26, 2012 | 07:45 AM
Powell Race Parts's Avatar
it comes up, as the lining beds, you just dont notice it much, as it doesnt come back up to production height.
I like the GMPP just the way it is to tell the truth
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
