New Intake Manifold Development Thread!!!
Old Mar 25, 2008 | 11:22 AM
  #76
Omega_5's Avatar
Wow.... Witt, that's awesome! Thanks!
Scythe... thanks for the comment.
Pics will be coming...
My head still feels like a beach ball today, but I'm still slugging away at it... being sick is one part of spring that I hate!
Old Mar 25, 2008 | 11:25 AM
  #77
Scythe_Snake's Avatar
Patience is a virtue, some members need to learn that.
Get better...then get to work on that. =p
Old Mar 25, 2008 | 11:50 AM
  #78
Deathscythe's Avatar
Hey man, you can't rush greatness..., just don't be like other companies and put things out before fully testing them to see that they work; and fit right.
I'm another on the list.
Old Mar 25, 2008 | 11:56 AM
  #79
Speedytec's Avatar
Don't forget the PCV orifice opening, as it is not on this drawing.
(What about a universal flange for both the LSJ and the L61 head. Just slightly different PCV positions...)
Old Mar 25, 2008 | 11:59 AM
  #80
Omega_5's Avatar
That's something I should point out now!
The test unit is going to be a mess of wires and sensors!
I'll be logging pre and post core air temps and pressures, as well as inlet and outlet water temps.
From that I can determine efficiency, heat transfer rate, heat soak, boost latency, and all kind of other goodies!
Old Mar 25, 2008 | 12:18 PM
  #81
Just do what you gotta do. I like having concrete information.
Old Mar 25, 2008 | 12:37 PM
  #82
Pully Police's Avatar
That just tells me that you are doing it right, with hard data to back up your design. People / Vendors should take note. I am really looking forward to how this turns out.
Keep it up - dont let people rush you - you have a good bunch of supporters in this thread who will gladly run interference for you if/when people start bitching
Old Mar 25, 2008 | 12:40 PM
  #83
Omega_5's Avatar
Thanks guys!
Old Mar 25, 2008 | 12:44 PM
  #84
f--in right!
Old Mar 25, 2008 | 02:06 PM
  #85
Black_bullet_ss's Avatar
This sounds like a great idea! put me down for one of these... Keep taking your time too man. Good things don't happen over night.
Old Mar 25, 2008 | 03:36 PM
  #86
Kennyspec's Avatar
Sorry to threadjack but Witt do you also happen to have the drawing of the exhaust flange?
Old Mar 25, 2008 | 03:42 PM
  #87
I think that if you go to GM tunersource, all the engine technical drawings are in the build book pdf's.
P.S. This is not a polite jab at getting you to not threadjack - I am just letting you know as there are a bunch of really good technical drawings in those pdf's
Old Mar 25, 2008 | 03:43 PM
  #88
Witt's Avatar
Yes.
Correct.
Old Mar 25, 2008 | 03:45 PM
  #89
Omega_5's Avatar
Cool... good to know!
  #90
Witt's Avatar
Here's the exhaust one:
Old Mar 25, 2008 | 03:49 PM
  #91
Omega_5's Avatar
Well... I found the document your refering too...
http://tunersource.gmblogs.com/Racer...06appendix.pdf
All I can say it... holy jeezus...
Old Mar 25, 2008 | 03:54 PM
  #92
There is one for the LSJ specifically and a general one aimed at the 2.2 which does make reference to the LSJ.
Lots of crap to take in
Old Mar 26, 2008 | 04:38 AM
  #93
it's good to know that there aren't that many things that need to be upgraded to get around 400 crank hp.
Old Mar 26, 2008 | 08:32 AM
  #94
Yeah - just pistons, maybe a bit of porting, and valve springs. I would also get some adjustable cam gears as NO ONE makes a direct fit cam in the LSJ unless you want to run a smaller base circle - which I dont want to do
Right from GM - Crank is good to 500+ hp, rods are good to 450 hp, the stock head can make 400hp as it is, the block will go as far as you want s long as you replace the cylinder liners which are good to about 400-450 hp, and the valves can handle a crapload also.
Old Mar 26, 2008 | 09:58 AM
  #95
Blown 4-banger's Avatar
In the original GM test build of the ecotec, the stock sleeves didn't fail until 750 hp.
Old Mar 26, 2008 | 12:34 PM
  #96
Area47's Avatar
Rent me! per hour
you need to pay more attention.
Old Mar 28, 2008 | 08:23 AM
  #97
Mega, any new news for us yet? How's it coming along?
Old Mar 28, 2008 | 08:34 AM
  #98
skymynx's Avatar
subscribed for results
Old Mar 28, 2008 | 09:25 AM
  #99
Omega_5's Avatar
Well, yesterday was the first day I got to work on it (not feeling so hot lately). And it ended up that I had a set back with the design.
My initial 2D CAD layout didn't quite do justice as to how tight of a fit it is on the head side.
So... now I have to tweak the core positions again to fit in the runners.
As soon as I get a design that I'm satisfied I can run though a simulation, I'll post a screen shot.
I just don't want to post a picture of something that isn't feasible.
Old Mar 28, 2008 | 09:26 AM
  #100
The L61 build book says to replace the stock liners with solid iron liners at about 400Hp...
...here is the million dollar question: Do the L61 and LSJ have the same Cylinder liners??
Sounds good!
Last edited by Pully Police; Mar 28, 2008 at 09:26 AM. Reason: Automerged Doublepost
