NGK Iridium or Copper
Old Jul 12, 2007 | 05:15 PM
06ViperTruck's Avatar
So what plugs are some of you guys running and whats beter NGK Iridium or Copper.
Thanks
Last edited by 06ViperTruck; Jul 12, 2007 at 05:15 PM. Reason: Automerged Doublepost
Old Jul 12, 2007 | 05:17 PM
Mikey851's Avatar
Thanks
I'm running the BKR7E step colder coppers and my engine is running smooth. Just to keep it simple, the Iridiums merely last longer than the coppers; copper is the best heat conductor and I believe the Iridiums are copper cored with iridium on the electrode for longevity.
Old Jul 12, 2007 | 05:18 PM
an0malous's Avatar
Copper is cheaper, and arguably a tiny bit better in high performance applications.
but Iridium, while more expensive, lasts alot longer.
I think either is good.
Old Jul 12, 2007 | 06:45 PM
Ryan07SS's Avatar
Do you have to gap the iridium spark plugs ?
Old Jul 12, 2007 | 07:00 PM
Mikey851's Avatar
Yes, you must always verify a proper gap.
Old Jul 12, 2007 | 07:18 PM
an0malous's Avatar
you have to gap all plugs.
never trust the factory gap without checking.
also if your modded dont just assume a certain gap is right.
test a few different gap settings to find what your car likes.
Old Jul 12, 2007 | 07:28 PM
Rodimus_Prime's Avatar
how exactly do you determine what it likes, in my previous L61 I used gaps from .030 all the way to .045 and nothing ever seemed to change
Old Jul 12, 2007 | 07:33 PM
an0malous's Avatar
Basically, go for the largest gap you can safely run with your car, before you begin to notice it doesnt like it.
things like a rougher running, rougher idle, spark blowout, sputters, misfiring, low down bogging etc etc.
F/I cars generally will need smaller gaps than N/A
IMO with these cars, start at 0.40
if it runs nicely there. use that.
if you notice any negative effects, drop down 0.02-0.03 at a time until it feels like the car is smooth.
Alot of guys with stage 2 or above like runnign 0.35.
Old Jul 12, 2007 | 07:37 PM
Mikey851's Avatar
It becomes more apparent when your particular car has either modifications or conditions it is put through that make adjusting gap from stock more crucial. Stock gap is optimal for gas mileage and emissions as well as power on a stock car. Say you go with the stage II; will it probably run okay with the stock plugs and gap (Assuming you run premium fuel), yeah it will although you could dial it in a little better for the situation. Now say you went to a 2.9" pulley, exhaust and an intake; at this point you would start running into a situation where the stock plug at stock gap cannot properly ignite the mixture. If you now install some step colder plugs and gap a little smaller than stock (Trying a few different gaps to see what works best) you would notice a smoother running engine that is able to provide the spark that is needed to get a full burn.
Ryan07SS's Avatar
Thanks for answering my question ! +1 rep for you .
Old Jul 12, 2007 | 07:42 PM
RA122324's Avatar
NGKs
Old Jul 16, 2007 | 11:14 AM
has anyone tried the AC Delco irriduims yet?
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Turbo6
Aug 27, 2015 08:37 PM
JohnnySasakiMGS
Jul 3, 2006 01:02 AM
Nauticabri
Apr 2, 2006 10:05 PM
SFPH
Jul 2, 2005 09:35 AM
