nitrous wiring ?
Old Sep 18, 2009 | 01:37 AM
Durtyss's Avatar
nitrous wiring ?
Im going to be wiring in my air/fuel lean switch. It needs to monitor 100 percent throttle so i can use included micro switch, or hook up to tps. If it is better for it to read off the tps, what wires do i connect to for 12v high, or a ground signal low or tps voltage heres link to part thanks dynotunenitrous.com/store/scripts/prodView.asp?idproduct=67 This is how book states if i make no sense. trigger/tps wire, is looking for source only when nitrous is spraying. it can be configured to detect 12v signal (high) or a ground (low) or tps thanks
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
