nitrous wiring ?
nitrous wiring ?
Im going to be wiring in my air/fuel lean switch. It needs to monitor 100 percent throttle so i can use included micro switch, or hook up to tps. If it is better for it to read off the tps, what wires do i connect to for 12v high, or a ground signal low or tps voltage heres link to part thanks dynotunenitrous.com/store/scripts/prodView.asp?idproduct=67 This is how book states if i make no sense. trigger/tps wire, is looking for source only when nitrous is spraying. it can be configured to detect 12v signal (high) or a ground (low) or tps thanks
