No Boost, Jumpy Idle After Meth Install
Hey guys, I'm having some big troubles here with my meth kit (devils own stage 2) after I installed it.
Currently, I have been following these instructions:
http://www.alcohol-injection.com/ins...2%20vers2b.pdf
http://www.alcohol-injection.com/ins...rn_redline.pdf
Black - Grounded to bolt on frame
Pink - Ignition on (Sunroof)
Blue - Pump's Black wire
Yellow - Taped off
Orange - Attached to Pink (If I didn't, the controller was running 24/7, with car off)
Green - Attached to MAP sensor (see link)
Pump's Red - Attached to pink (again, if I attached to battery, it would start spraying with car off)
Pump's Black - Attached to blue
My issue, is that when everything is connected, I sometimes throw P0108 at start up, and then I cannot go into boost while driving. My idle is also super jumpy, and can't hold steady.
When I disconnect the pump (full the fuse for JUST the pump's power), and disconnect the MAP sensor, my car runs perfectly fine.
I do have tons of gauges, so if anyone needs more specific info, PLEASE HELP!!!!
Yellow - Taped off
