nornal iat question
Old Jun 5, 2013 | 05:11 PM
Tjolley's Avatar
Mine usually brings my temps within a degree or 2 of the outside temp.
The KC works well on really hot days.
At least untill i build my new manifold. Think i said tomuch already.
Old Jun 5, 2013 | 05:44 PM
Yes you certainly did!!
Old Jun 5, 2013 | 06:43 PM
Tjolley's Avatar
Lets say Solid works professional works good. Lol
Old Jun 5, 2013 | 08:26 PM
Murdered SS's Avatar
I didnt mean you can't give it throttle, but on super hot days it's best not to beat on the car.
I'm happy to live in Northeastern PA. Temps only get hot for a short period of time. Most of the time it's nice and mild.
Yea i get you i dont beat on it at all when its hot ass hell out. i just cruise but theres always alot of traffic and that when my temp go up.
Old Jun 5, 2013 | 08:27 PM
redcobalt07's Avatar
On my g8 it's like 2 degrees higher unless I'm standing still.
Old Jun 5, 2013 | 08:34 PM
Tjolley's Avatar
G8's dont monitor charge air temps. They only see temps at the air filter.
Old Jun 6, 2013 | 12:52 AM
05RLS2's Avatar
Mine are anywhere from 20 to 30 dregress over ambient while cruising
Those are perfectly normal IAT2's.
The addition of a dual pass aids in recovery. Not so much IAT2 temp level.
I am really beginning to wonder if a dual pass and option b does much for those that are running a 2.9 or larger pulley. For the average person that is not racing or doing back to back full throttle pulls, just merely cruisng with the occasional spirited driving, it seems that the stock cooling system is more than sufficient to keep things in check.
I am sure some will jump in flame for saying this, but just my opinion and observation
Old Jun 6, 2013 | 01:02 AM
Id assume its decent enough to handle a stock pulley atleast!
Old Jun 6, 2013 | 07:11 AM
Staged07SS's Avatar
Administrator
Administrator
Temps will always rise in traffic, no matter how good your cooling mods are. In traffic, you have little to no airflow to bring in cooler air. The key is the recovery after being in traffic. Do your IAT2's drop fast?
I did a 1st-3rd gear pull last night, and my temps at the top of 3rd (7500 rpm) were 140, but dropped immediately back down to 15-20 over IAT1.
Yes they do. They are for recovery. Not droping your cruising temps.... Remember I run a GMR 76 mm (2.992") pulley.... The dual pass/Opt. B help.
The best cooling option I've done for dropping cruising temps was adding my OTTP heat exchanger.
Before the addition of my dual pass, IAT2's took a little to drop. Once I installed the GMR dual pass, temps drop right after the pull.
Opt. B should have been installed on our cars from the factory. It removes all air from the intercooling system. The LSJ is not a one bleed and your done kinda system.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
