o2 sensor bypass, will this work?
Maybe if I knew more about how jthe internals of the O2 Sensor works I could tell you.
I thinkt he 12 Ohm resistor part is probably not required though.
Probably eayser and better just to get your downstream O2 sensor deleted in your tune.
im waiting till spring to get tuned so i can ride the rocket to work in the down time. will i pass emissions with it tuned out? i put the antifoulers in but still throwing a system lean code p0171 after i put my catless zzp dp on, should i order a angled 02 extender.
thanks
thanks
Sl0wbaltSS
Nov 21, 2018 11:11 PM
