o2 sensor bypass, will this work?
Old Dec 4, 2012 | 11:37 AM
holidai's Avatar
Original link O2 sensor bypass
I know how to wire in just not good with the technicals yet any help
Old Dec 4, 2012 | 11:57 AM
insylem's Avatar
Maybe if I knew more about how jthe internals of the O2 Sensor works I could tell you.
I thinkt he 12 Ohm resistor part is probably not required though.
Probably eayser and better just to get your downstream O2 sensor deleted in your tune.
Old Dec 4, 2012 | 12:01 PM
Hockeyman's Avatar
use spark plug anti-fouler from Vatozone or Ho'Reilly's, worked for me before I deleted code in HPT.
Old Dec 4, 2012 | 11:31 PM
holidai's Avatar
im waiting till spring to get tuned so i can ride the rocket to work in the down time. will i pass emissions with it tuned out? i put the antifoulers in but still throwing a system lean code p0171 after i put my catless zzp dp on, should i order a angled 02 extender.
thanks
Old Dec 4, 2012 | 11:40 PM
Hockeyman's Avatar
lean code doesn't occur from downpipe installatiion. You have an intake?
Old Dec 4, 2012 | 11:45 PM
JapEatr's Avatar
South Central *********
171 isnt from downpipe. Intake or vacuum leak post maf. Check your lines
Old Dec 5, 2012 | 12:23 AM
Tjolley's Avatar
sounds like a Vacum leak or a leak at the front o2...
Old Dec 5, 2012 | 07:26 AM
holidai's Avatar
I do have a intake,, but never had a problem with it, i looked the code up in shop key and it says could be allot of things, o2 sensor was one of them
Old Dec 5, 2012 | 09:47 AM
Hockeyman's Avatar
apparently you do...very common on these cars to throw codes untuned with an intake.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
jmelton327
Sep 26, 2015 10:04 PM
