odbii codes
Old Jan 9, 2009 | 03:52 PM
knighthawk's Avatar
odbii codes
dose anyone know of a good site that lists the spesific codes for the cobal that is free?
Old Jan 9, 2009 | 04:09 PM
TRANSAM197781's Avatar
you can get obd 2 codes off the internet just google obd2 codes
Old Jan 9, 2009 | 04:13 PM
knighthawk's Avatar
I know was just wondering if there was a site that was more cobalt specific instead of getting sites talking about 99 ford tauruses and crap like that.
Old Jan 9, 2009 | 04:14 PM
beamer1341's Avatar
obd2 codes are pretty generic in nature all about the same...
being a n00b here:
https://www.cobaltss.net/forums/showthread.php?t=3480
search button......works wonders
Old Jan 9, 2009 | 04:28 PM
knighthawk's Avatar
thx i did a serch but i did it for a specific code and got no hits that list also dsnt have the code listed but it is a good referance point thx
Old Jan 9, 2009 | 04:30 PM
mcphatty's Avatar
what code are you getting?
Old Jan 9, 2009 | 04:39 PM
beamer1341's Avatar
found out himslef i guess??
Old Jan 9, 2009 | 05:22 PM
knighthawk's Avatar
i got a p1744 code that is pending acording to the recorder that i have it says it is pending so it might be a old code that never got cleared from previous owner
P1744 Torque Converter Clutch System Stuck in Off Position.
Old Jan 9, 2009 | 05:49 PM
HunterKiller89's Avatar
^^ no bueno. bye bye fuel economy if that is the case.
Old Jan 9, 2009 | 05:54 PM
EXsoccer1921's Avatar
is your CEL currently on? or did you just hook up the scanner and come across that code in the history?
because if the cause of the code being thrown is fixed, but the CEL is not cleared, it will clear itself after 3 nonproblematic ignition cycles. and then it will be in the code history regardless of if its cleared manually or by the ecu for another 40 cycles
Old Jan 10, 2009 | 02:41 PM
knighthawk's Avatar
I was useing a recorder that i have that monitors all sorts of things while you are driving and records them. then you plug it into your computer when you get home and gives you all the info everything from how fast you drive to various temp and also monitors for problems and misfires and all sorts of crazy stuff.
Apparently my roomate borrowed it without telling me and never cleared the data so the code was actually from his car not mine. Which is great now that i know but had me worried for a bit when i thought it might be from my car.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
