Official catch can/crank case vent system thread
it was called sarcasm. please learn it. it is used a lot.
the point has already been stated as to why the baffle is there. you more or less voided the whole purpose behind it. i do hope you enjoy the oily mess that will show up later on.
the people on ls1tech {that you used for a reference} ended up going the cheap route instead of getting the proper parts to do it. IE taller covers, or spacers for the covers. they also have an oil issue due to this.
however, in the end, your failure will happen as others who have been down this road before have state what will happen.
this is where i reserve the right to say "i told you so" for future use.
i had it figured out a long time ago.
since you seem to be the great master of science/physics. explain to the rest of the board your reasoning as to why. unknown to the engineer's who built the car and their reasoning, im sure your's is far superior and more in depth than just basic air flow calculations and computer simulated models.
sad actually all that effort tearing apart the rocker cover is good to find out how it is, but the orifices are critical to generate vacuum levels, and I think both Area and Mr. B indictated why your system is unfortunate.
It is yours and you are happy with it, but I sure would not recommend this for most people, as it will really not draw any vacuum what soever.
But good effort. BTW, powdercoating ovens at 300-350 degrees F wont melt the plastic. If that temp did, then the motor would be in serious trouble, as oil can see those temperatures at max loads, and GM design well above oil temps achieved in testing.
That said, the LSJ PCV system is not perfect, the LNF is better, the entire top runner of the rocker on the exhaust side has filters and a specific chamber and orifice on the dirty side vent where we tap in our seperators; please dont get confused about valve coking, the issue with LNF valve coking is unique to DI motors.
Area47 and Mr.Belvedere have a lot of LSJ experience and I certainly pay attention to their insight.
I could throw the metal baffle back on there and tac aluminum on the stock holes Powell which would help seperate the oil from the vac air but anyone that welds the bung to the back of the valve cover is also below the steel baffle. Just got off the phone with MRB and his bung is below the baffle, so there is no difference below or above the baffle. His is working fine and he does want to change it but to pull more crank case pressure off the engine.
Now I will run my setup and keep an eye on it but with the location of my drilled hole there is no splash from the lobes, I made sure that it was offset from a lobe. I have no oil in my catch can. I havent ran it long enough to feel comfortable about saying its for everyone but I am also not sure right now that its "a failure waiting to happen".
Hahns sheet metal manifold comes with a check valve and tube off the heads pcv but all that does is get gunk on the valves and cooks it on. LNF is bad too, not sure why you say its so much better, there are a lot of LNF guys complaining of valve crud from the LNF PCV. Just saying...
I dont doubt MRB knows his stuff I talk to the guy all the time, he has my block right now and he sleeved it for me and got the machine work done. Should have it soon. But to say as a baffle is a failure waiting to happen doesn't have a lot to back it up.
I dont expect the OP to do what I am doing but the typical cobalt owner isn't going to rip the VC apart much less remove it.
The LNF PCV stock has a fresh air inlet, to help with NOX levels, which turbo's suffer from by their nature, and thus fail emissions So the LNF is no doubt, a more comprehensive PCV system in design, it had to be to pass emissions. Thats why I say its better, because it is. LSJ has one vent out port in the cover, one out port in the IM check valved, and NO SEPERATE fresh air inlet. The S/C doesnt have the same NOX issues that turbo motors have.
GM have some of the finest engineers on the planet, and the ecotec engine series designed and built by SAAB initially and taken over by GM Powertrain, won the "ten best world wide engine" awards from Wards for about a decade iirc.
It could be that from time to time hotrodders and mod guys stumble across some interesting and even effective solutions for all sorts of things, but I have to say that without serious qualified engineering input and design/test work and information, some of the stuff I see on forums, just doesnt have a chance to work well .
Last edited by Powell Race Parts; Dec 6, 2012 at 08:19 PM. Reason: Precise wording added
The LNF PCV stock has a fresh air inlet, to help with NOX levels, which turbo's suffer from by their nature, and thus fail emissions So the LNF is no doubt, a more comprehensive PCV system in design, it had to be to pass emissions. Thats why I say its better, because it is. LSJ has one vent out port in the cover, one out port in the IM check valved, and NO fresh air inlet. The S/C doesnt have the same NOX issues that turbo motors have.
- Low/medium loads; vacuum in the manifold, mani valve open; high mani vacuum pulls gas out of the crank AND fresh air in through the cover tube to vent the crank. (thats why it's connected to the inlet after the MAF. It's metered air)
- High loads; overpressure in manifold, valve closed, blow by gasses will be suched through the valve cover to the (low vacuum) inlet before the (wide open) TB.
Off course every sutuation in between applies too...
the second port I did for PhilZoot is tapped as he requested, into the rocker vent that is sealed by the gasket from the valve train, and travels through the head, and splits into the two block ports venting the base of the motor. To work like the LNF system, this port would have to be checked fresh air inlet with the inlet before the maf
I think the (LSJ) PCV system works different as you decribe here, as it's a 2 way system. (Just Google "PCV system")
For those in the "know"...
Im wanting to do a proper system and had already planned on going from the stock nipplie to my sealed catch can and back to my intake tract.
That being said how do you drill and weld into the pan above the baffle and not have shavings and such stuck in there?
Is there a specific position I should put my an bung?
Should I block the stock port or just pull out the steel insert and weld to that?
possible pcv problem
the other night i was doing 110 in 5th dropped to 4th floored it and let off about 130 and 6500 rpm i coasted to 50 mph then the check engine light started flashing and my 06 ss/sc was missing and running rough. stopped looked under hood and entire engine bay was covered in oil. dip stick was popped up other than that no other visible problems.. any ideas what caused this and what i may have broke? feel free to email me @ lnhetzner_stephens@yahoo.com im in a pinch and need to get my car fixed fast
I hope a PCV problem is your only issue....
i see another build thread in the future
mine was doin the same thing..it ended up being a cracked piston...
do this
start ur engine and pull the vent line off ur intake...put ur finger over the port on your intake to keep the engine from rinning funny.. if u have a bunch of air hissing out of the vent tube i would be its a cracked piston..or broke ring
do this
do ur self the favor and buy a spare lsj block and get it to mrb and let him work his magic on it
timely thread, as I want to do this this winter while I'm apart
so consensus seems to be--
-10 welded above tin plate, but not specifically at one of the crankcase passages, run to a air / oil separator can, then to the cold air tube. Block PCV passage in the cylinder head.
that about right?
now I gotta ask, and I know this has been asked before, what about using exhaust evac with a check valve, instead of intake ?
that about right?
that about right?
that about right?
and with the check valve, if there were positive psi in the exhaust at low rpm it wouldn't back flow into the crankcase.
