Official Procharger Build Thread
Old 06-21-2007, 05:08 PM
  #301
Speed Mafia's Avatar
DAMN JBJ Pro Performance does not play 7K on the car and its getting procharged!
the belt is not tight it is on there to make sure it is getting aligned correctly...etc
Looks sick for sure, and yeah i tried to tell the Redline guys it fit just fine and if it will fit a Cobalt ppfftt the ion guys have it made! I am just amazed how clean it looks and imagine if you had a polished blower in there with the bracket polished (6061 T-6 polishes nice) with chrome piping...straight up
Old 06-21-2007, 05:11 PM
  #302
chevytech007's Avatar
yah what he said ^^^
And those are 7000 very hard miles !!!
Old 06-21-2007, 05:15 PM
  #303
ptrblkz24's Avatar
Looks nice sitting in there.Hopefully its better than rsm's setup with misaligned pulleys and shredded belts and ****.It looks better judging by the pics.Good luck with the install.That things gonna be a beast!!
Old 06-21-2007, 05:43 PM
  #304
elecblue06's Avatar
HOLY ****!!!!!!!!!!!!!!!1 +1 rep chevy thats sweet.. i can't wait to see it finished..
Old 06-21-2007, 06:20 PM
  #305
WSFrazier's Avatar
TQ Damper FTL. BWoody FTW.
Old 06-21-2007, 07:20 PM
  #306
Its not bolted up yet(still working on that) But its just the basic set up and no the bolt will not be hitting anything when im done. I promise you that. Im so excited my self.
Bring on the power.
Old 06-21-2007, 07:32 PM
  #307
Mikey851's Avatar
Originally Posted by denny
So no more INGALLS torque dampner... gain a power mod and loose a traction mod... what to do?!?
Thats a very tight fit in there with the screws from the charger touching the pulleys...maybe its just the angle..
Also It looks like the windshield washer bottle is going to have to be relocated..
I think urethane mounts are sufficient. If the urethane allows less movement than the torque damper can in the first place if you have both of them the torque damper probably doesn't even have to work that much.
Old 06-21-2007, 08:01 PM
  #308
BravoPuma6's Avatar
Originally Posted by chevytech007
These are just some pics. I havent got that far but here ye go !
only has 7,000 miles on it .
NICE!!!!!!!!!!!!!!!!!!!
more pics! ur gonna go air to air 2? why did u choose a c2 over the c1?
Old 06-21-2007, 08:10 PM
  #309
No air to air just the stock intercooler. Its just the mockup thats a c2 but both will work.
Old 06-21-2007, 08:12 PM
  #310
BravoPuma6's Avatar
who's gonna tune it?
Old 06-21-2007, 08:20 PM
  #311
2K5SS/SC?'s Avatar
Is there a way you can clock it so you could just a tight "u" bend or 2 90*'s and plum it to the intake for the shortest route possible? Looks great by the way. Almost looks too simple!
Old 06-21-2007, 08:33 PM
  #312
ptrblkz24's Avatar
Did you have to cut the radiator support to make it fit?The edges look aittle rough.
Old 06-21-2007, 10:47 PM
  #313
As for piping it will be a nice smooth 90 degree bend down to a 45 then straight to the TB! can you say 36" of piping! yeah it will be very short and 36" is probaby the longest it will be! also JBJ said the procharger pulley sits in the stock location of the Roots Blower! very sick!
Old 06-22-2007, 01:18 AM
  #314
There is a bit of a clearence issue but its no big deal. Its room for engine movement.
Also the pipe will go straight to the throttle body as speedmafia has said.
Old 06-22-2007, 10:35 AM
  #315
beamSS's Avatar
how bout the filter is there enough room in there?
Old 06-22-2007, 11:18 AM
  #316
bc3tech's Avatar
k&n makes a filter that fits perfectly - i will try and dig up the dimensions and part number again if i can find it.
edit: here it is! http://www.knfilters.com/search/prod...x?Prod=RU-2990
Old 06-22-2007, 11:50 AM
  #317
Yeah we will be using a tight fit intake rubber fitting that i use on MAF systems on the ION and run either a 4" CAI with a fatty K&N Air Filter on the end...
The Air Filter we used for Bc3tech will be updated shorty with this same setup but for 03-04 IAT cars it will look sick!
Old 06-22-2007, 12:43 PM
  #318
RedlineBrian's Avatar
Can't wait to see the finished product. Great work!
Old 06-22-2007, 01:40 PM
  #319
2K5SS/SC?'s Avatar
Good deal. Where exactly is the MAF going in this whole system, and are you using a recirculating BOV or an atmospheric BOV?
Old 06-22-2007, 02:35 PM
  #320
We are still deciding if we want to utilize the LS1 MAF setup and Atmospheric BOV or Recirculation setup those are in the air and what is going to give is the best performance and long term results.
Have any idea's let us know
Old 06-22-2007, 02:45 PM
  #321
0redline6's Avatar
h ave a question... i have a redline... so will the ion kit you have pretty much bolt right up to that?... and does it have a fmic??..
Old 06-22-2007, 03:27 PM
  #322
Yes it will bolt right up only parts different from the 2.2L ION is....
ION 2.0LSJ ProCharger Kit Includes
Intake Manifold Adapter
FMIC w/Mandrel Bent Piping 2.5"
All Silicone Hosing with Clamps
BOV
CAI w/K&N
6061 T-6 Bracket w/Mounting Block
C-1 or Opt for a C-2
Pulley Size (how much PSI you looking for you choose)(on ChevyTech we are going 2.95)
Misc Parts, Bolts, Washers, Tie's, vacuum Hose...etc
Remember you have more room in the Redline then the Cobalt guys so install for sure will be no more then 2 hrs!
Then after test drive and make sure belt is lined up it and a spin around the block on 1-2psi...start tuning!
Old 06-22-2007, 04:49 PM
  #323
0redline6's Avatar
BOV
CAI w/K&N
ok so i am very very intersted in this actually lol i get back from a cruise on the 9th of july so by the end of july i will b ordering this... i was looking to at the end run maybe like 23-24 psi.. i will prbly get the c-1 to keep the price down a bit.. but for starters i would like to know what the stock internals will hold lol.. umm probly say 19 psi.. b4 i do the pistons an what not.. an i would like the fmic an use my stock intercooling system also to keep it cool lol... if you can shoot me a pm to about how much that would be for the kit i would appreciate that... with a pulley to make about 18psi an a pulley to make about 23-24 psi.. and also what kind of bov do u sell with the kit?
Old 06-22-2007, 06:10 PM
  #324
Here are the pulley options below starting from largest to smallest...
6 rib belt
3.55"
3.40"
3.20"
3.10"
2.95" (ChevyTech 15-17 PSI guestimate)
2.80"
2.67"
2.55" (0redline6 22-24 PSI guestimate)
2.25"
Now for the customer guys....8 rib pulley! no belt slippage here!
3.85"
3.75"
3.65"
3.45" (BC3TECH 10 PSI)
3.35"
3.25"
3.15"
3.05"
2.95" (BC3TECH Has it for Emergency's)
2.85"
2.75"
2.65"
Then we can always go Cog setup!
Pm will be sent shortly
Old 06-22-2007, 07:00 PM
  #325
Luv2Race's Avatar
Im stuck on whether I want to go with this nice ass setup with the progcharger or go with a full swap turbo kit. I want to make some great power and I have heard the turbo kits that are being worked on sound promising with power and all and thats what im looking for 350whp+ any help or opinions would be nice.
Quick Reply: Official Procharger Build Thread
