Official Procharger Build Thread
DAMN JBJ Pro Performance does not play 7K on the car and its getting procharged!
the belt is not tight it is on there to make sure it is getting aligned correctly...etc
Looks sick for sure, and yeah i tried to tell the Redline guys it fit just fine and if it will fit a Cobalt ppfftt the ion guys have it made! I am just amazed how clean it looks and imagine if you had a polished blower in there with the bracket polished (6061 T-6 polishes nice) with chrome piping...straight up
Looks nice sitting in there.Hopefully its better than rsm's setup with misaligned pulleys and shredded belts and ****.It looks better judging by the pics.Good luck with the install.That things gonna be a beast!!
Its not bolted up yet(still working on that) But its just the basic set up and no the bolt will not be hitting anything when im done. I promise you that. Im so excited my self.
Bring on the power.
Bring on the power.
So no more INGALLS torque dampner...
gain a power mod and loose a traction mod... what to do?!?
Thats a very tight fit in there with the screws from the charger touching the pulleys...maybe its just the angle..
Also It looks like the windshield washer bottle is going to have to be relocated..
As for piping it will be a nice smooth 90 degree bend down to a 45 then straight to the TB! can you say 36" of piping! yeah it will be very short and 36" is probaby the longest it will be! also JBJ said the procharger pulley sits in the stock location of the Roots Blower! very sick!
k&n makes a filter that fits perfectly - i will try and dig up the dimensions and part number again if i can find it.
edit: here it is! http://www.knfilters.com/search/prod...x?Prod=RU-2990
Yeah we will be using a tight fit intake rubber fitting that i use on MAF systems on the ION and run either a 4" CAI with a fatty K&N Air Filter on the end...
The Air Filter we used for Bc3tech will be updated shorty with this same setup but for 03-04 IAT cars it will look sick!
Have any idea's let us know
ION 2.0LSJ ProCharger Kit Includes
Intake Manifold Adapter
FMIC w/Mandrel Bent Piping 2.5"
All Silicone Hosing with Clamps
BOV
CAI w/K&N
6061 T-6 Bracket w/Mounting Block
C-1 or Opt for a C-2
Pulley Size (how much PSI you looking for you choose)(on ChevyTech we are going 2.95)
Misc Parts, Bolts, Washers, Tie's, vacuum Hose...etc
Remember you have more room in the Redline then the Cobalt guys so install for sure will be no more then 2 hrs!
Then after test drive and make sure belt is lined up it and a spin around the block on 1-2psi...start tuning!
Yes it will bolt right up only parts different from the 2.2L ION is....
BOV
CAI w/K&N
BOV
CAI w/K&N
ok so i am very very intersted in this actually lol i get back from a cruise on the 9th of july so by the end of july i will b ordering this... i was looking to at the end run maybe like 23-24 psi.. i will prbly get the c-1 to keep the price down a bit.. but for starters i would like to know what the stock internals will hold lol.. umm probly say 19 psi.. b4 i do the pistons an what not.. an i would like the fmic an use my stock intercooling system also to keep it cool lol... if you can shoot me a pm to about how much that would be for the kit i would appreciate that... with a pulley to make about 18psi an a pulley to make about 23-24 psi.. and also what kind of bov do u sell with the kit?
6 rib belt
3.55"
3.40"
3.20"
3.10"
2.95" (ChevyTech 15-17 PSI guestimate)
2.80"
2.67"
2.55" (0redline6 22-24 PSI guestimate)
2.25"
Now for the customer guys....8 rib pulley! no belt slippage here!
3.85"
3.75"
3.65"
3.45" (BC3TECH 10 PSI)
3.35"
3.25"
3.15"
3.05"
2.95" (BC3TECH Has it for Emergency's)
2.85"
2.75"
2.65"
Then we can always go Cog setup!
Pm will be sent shortly
Im stuck on whether I want to go with this nice ass setup with the progcharger or go with a full swap turbo kit. I want to make some great power and I have heard the turbo kits that are being worked on sound promising with power and all and thats what im looking for 350whp+ any help or opinions would be nice.
