I for one could car less about going to the track, I would rather have street bragging right them a grenaded lsj trans
Originally Posted by SCcobaltSS
(Post 6004595)
Not sure about the harness I used my LSJ alternator.. The bolts from the LSJ will not work unless you have a 1" steel spacer between the head of the bolt and the alternator. LSJ bolts are 1" longer due to the tensioner bracket.
ive got pix!...... soon to come cuz im eating.
Hey I got mine down only thing I need now is I have a 2.4 throttle body on it that's 6 pin and my harness is a 8 pin lsj what do I ge for that
a 2.4 tb? what manifold it this? ^^^
Originally Posted by Dr.Balt407
(Post 6004862)
(Post 6005082)
welcome bra! :guns: haha |
(Post 6005082)
welcome bra! :guns: haha My lsj throttle body harness to connect this 2.4 tb |
same one i'm running
(Post 6005399)
jonathan how much did you end up spending on the hahn stage V set up cause i am looking at the stage 2 or 3 zzp turbo kit next year let me know
you will need the 2.4 tb, shorter tb to intake mani bolts, and zzp's adapter for the pinout...did you get the kit or what?
Does the 2.4throttle body and spacer come with the zzp complete turbo kit?
don't need a spacer with the 2.4
Originally Posted by Frew
(Post 6004646)
really? tell the guys who strip the teeth off third gear rolling into a pull that. lol some get lucky with these transmissions. some don't. fortunately i have been lucky so far
(Post 6005699)
Originally Posted by zrated89
(Post 6005705)
i was more so talking about launching with a turbo vs a blower. If youre running 30psi and start pulling like a jet engine while going into boost in third after switching gears than i can see that being a possibility but very unlikely
http://i813.photobucket.com/albums/z...0/e8e8e2d6.jpg |
Originally Posted by INFE
(Post 6005722)
Lol I distroyed 3rd gear with a turbo! What are you talking about!
I did a pull 1-2-3 and boom. From a dead stop.
Yea third is definately the weakest link in our trans. Thats why i have a spare sitting on my porch for when my slicks go on
Originally Posted by donald
(Post 6005626)
thats not bad whats the comparisson on the two i don't have a supercharger to sell because i am na but the stage 2 zzp is about 3000 with 60's and 2800 without but i was also gonna put rods,springs,cams,and hahn full 3 inch exhaust maybe wisco pistons not sure but i figues all together with stage 1 axels about 5 grand what do you think
well as far as i know the main difference between the two kits are the turbo setups. hahn using a s20g which is a relative small turbo compared to zzp's s252 which is considered a much larger turbo. also hahn uses internal waste gates while zzp uses external. also hahn turbo set up is good for a good reliable 360-380whp car. when you can make 400whp+ on zzps kit using same or less amaount of boost. although i know for 2.2s and 2.4s things change a bit since the horse power claims on there set ups havent been as high unless you do internal work as you plan too. but then again thats much more money to invest if you know what i mean. we have a local 2.4tc that is in the 250whp range on only about 7-10 psi i believe and also on stock internals. i think he has the zzp stage 2 turbo kit
is he on here but i know zzp said just with the stage 2 and nothing else it will put you up 100 hp and 150 for the stage 3 but if i go stage 3 then i will have to put a roll cage in my car to go to the track cause they are mandatory after you pass 11.999 at bradenton and i know other track are more anal about power to i know orlando if you pass 8.8 in the 8th mile you need a helmet so idk and is he automatic cause i am
where do you find the hahn turbo kit at |
his hahn turbo kit was used. your best bet is zzp. unless you are on slicks you are not getting anywhere near 11.99
