Official Turbo LSJ thread!!!
#3226
If you were closer I def could
Yep I have it and USMCFieldMP had it before I did
faces the turbo to the back side of the block and the exhaust has a straight path instead of having a huge bend in it
its actually not horrible, the turbo being large cramps the space, but if I were running a smaller turbo there will be a **** ton more room in there
#3231
yep it is the Sound Performance Quick Spool Valve. I bought it from Sound Performance, they are def expensive, mine was $700 and some change. It also took me like 3 months to get it because apparently they are built to order. Im the only cobalt with one as far as I know.
#3232
#3233
#3236
ugh **** this cobalt. leaving work today i came out car had a big cloud of smoke around it. mech said its def burning oil. but the level hasnt gone down any and its only at idal sometimes. 1 of 3 things 1 blown turbo seaals (fucked) 2. incorrect seated rings (im super fucked in the ass) 3 nothing at all .. oil is black im changing tommrrow and praying for 3. lol
#3238
im at 1500 miles right now. the turbo had minimal shaft play when i installed back on.. ill check when i boost leak test tommrrow. if it is the turbo shoudnt be that bad. i cant afford my setup till january though.. maybe if i buy a cheap k04 and swap exaushht housings? as mine is for a t3 flange
#3244
wont have access to that till monday.. oil pressure is fine while driving .. doesnt make boost but only because the charge pipe isnt tight and my bov leaks air. fixing tommrrow.
