Official Turbo LSJ thread!!!
Old Feb 21, 2013 | 07:31 PM
  #4201
c130aviator's Avatar
completely stock fuel system with 80's. Great idle.
Old Feb 21, 2013 | 07:39 PM
  #4202
Cmyler34's Avatar
Damn how does your fuel pump have enough to pump gas for that? My tuner would only tune me at 15 psi Bc the stock fuel pump couldn't pump enough gas for my 60s at 19 psi. My a/f was 12.5 he said that wa risky an could blow. Opinion on this?
Old Feb 21, 2013 | 07:44 PM
  #4203
kept upping the boost until the afr started to rise. at 420 it was leaning out but only a little. Backed it off to 22 psi and left it at 411 for DD. I even brought the timing back to 18 degrees and still made over 400... Did you see the E85 symbol in my sig?
Old Feb 21, 2013 | 07:49 PM
  #4204
Cmyler34's Avatar
I'm confused.. What's your air fuel when Floored?
Old Feb 21, 2013 | 07:59 PM
  #4205
drops down to high 10's on gas setting but since stoich is always 1 to whatever you convert it to its the same for gas on a wideband. My tuned stoich AFR is 10.20020 (e70 winter blend e85)
Old Feb 21, 2013 | 08:04 PM
  #4206
Cmyler34's Avatar
And this is on stock fuel pump ? What do you recommend for me then? When I was at 18psi my a/f was 12.5. And that's to lean. Why is yours not as high as might? But at 15psi mines 10.8 like yours. But if I add more boost it leans out. I have 60s could that matter? My fiends having the same problem as me. Care to explain lol i don't get it
Old Feb 21, 2013 | 08:14 PM
  #4207
tuner needs to add fuel to the power enrich eq ratio vs rpm.
Old Feb 21, 2013 | 08:22 PM
  #4208
Cmyler34's Avatar
He did that. And it still didn't have enough fuel, he threw all the fuel at it and it was still lean. I don't get why.
Old Feb 21, 2013 | 08:30 PM
  #4209
it has been said here a few pages back that the stock pump will flow more than even I am running. ALOT more. My next guess is your idc. is it at 100+ percent? What is it showing at over 15 psi? It aint your pump man.
Old Feb 21, 2013 | 08:32 PM
  #4210
mrbelvedere's Avatar
get a new tuner he is clueless aparantly
Old Feb 21, 2013 | 08:35 PM
  #4211
Cmyler34's Avatar
Idk ill have to check, what's an idc? And at over 15 psi my air fuel was 12.5. Which was at 18psi. So what do I need to change for it to be able to handle that
Old Feb 21, 2013 | 08:37 PM
  #4212
Cmyler34's Avatar
There's no other tuners around :/
Old Feb 21, 2013 | 08:58 PM
  #4213
Cmyler34's Avatar
So do I need 80s? I'm running 60s is that to small ?
Old Feb 21, 2013 | 09:03 PM
  #4214
SylverSS/SC's Avatar
Idc = injector duty cycle
Old Feb 21, 2013 | 09:08 PM
  #4215
Cmyler34's Avatar
My tuner must be dumb as **** or something.... Idk what to Do
Old Feb 21, 2013 | 09:12 PM
  #4216
What turbo are you on? Just curious.
Old Feb 21, 2013 | 09:17 PM
  #4217
Cmyler34's Avatar
Super 20g same as you.
That's why I'm so confused lol
Old Feb 21, 2013 | 09:20 PM
  #4218
Cmyler34's Avatar
  #4219
MP Cobalt's Avatar
Stock fuel system on an lsj should be good to like 500.
Old Feb 21, 2013 | 09:27 PM
  #4220
Fuel pump dying?
Old Feb 21, 2013 | 09:30 PM
  #4221
TStone's Avatar
Where exactly are you located in Ohio?
Old Feb 21, 2013 | 09:35 PM
  #4222
i have a safety recall on a fuel pump issue recall is dated nov 2012 recall number 12190. Says the return port on the fuel pump module may crack, which could cause a fuel leak. Check to see if you arent leaking fuel or smell fuel after driving your car.
Fuel pump dying?
fuel pump wiring/ground
Last edited by c130aviator; Feb 21, 2013 at 09:35 PM. Reason: Automerged Doublepost
Old Feb 21, 2013 | 09:37 PM
  #4223
or just covering his but and keeping your car from blowing up.
Old Feb 21, 2013 | 09:41 PM
  #4224
steveobed's Avatar
what part of ohio are you from? just curious
Old Feb 21, 2013 | 09:46 PM
  #4225
Cmyler34's Avatar
I'm located in Toledo Ohio, and my fuel pump is fine I had that checked I heard about the recall. No cracks or leaks.. Idk what else it could be?
