Official Turbo LSJ thread!!!
Old Oct 13, 2012 | 09:23 AM
  #2951
MP Cobalt's Avatar
HAHAHA yeah I'll have to try that swaybar trick. you on coilovers? N the fusebox is a pain in the ass to remove itself also damn cobalt crap
Old Oct 13, 2012 | 10:48 AM
  #2952
jhaddock21's Avatar
Ok I'm doing the turbo swap with the zzp kit. Which lines should I T off of to run a line to my boost gauge for the best reading. I know the bov should have its own line. So should I go off of one of the lines that goes from the manifold to wastegate? Mp cobalt what did you do?
Old Oct 13, 2012 | 04:24 PM
  #2953
rivaladore's Avatar
No removing the fuse box is easy, removing the thermostat was a pain in the ass. But removing the fuse box makes changing out the thermostat much easier
Old Oct 13, 2012 | 04:59 PM
  #2954
EXsoccer1921's Avatar
loooool i'm so backwards. ordered my rear wheel/tire setup before the front slicks.
Old Oct 13, 2012 | 06:13 PM
  #2955
BlkWdoSS's Avatar
o thats an easy problem to fix, just swap it to RWD... lol just ******* with you, wish I could use my slicks, they are hanging out in storage.
Old Oct 13, 2012 | 06:40 PM
  #2956
nah these tires wouldn't be able to hold the power hahah. you guys will see
Old Oct 13, 2012 | 07:08 PM
  #2957
BLAZIN07SS's Avatar
I'm too JDM for you
You ordered skinnies, it's not too hard to figure out lol
Old Oct 13, 2012 | 07:56 PM
  #2958
skinny you!
Old Oct 13, 2012 | 09:45 PM
  #2959
BlkWdoSS's Avatar
who makes skinnies in our bolt pattern?
Old Oct 14, 2012 | 04:25 AM
  #2960
no one
Old Oct 14, 2012 | 08:36 AM
  #2961
MP Cobalt's Avatar
I ran mine off the bov line. i wasn't pulling are from the wastegate. i wanted to make sure it was accurate
Old Oct 19, 2012 | 12:13 AM
  #2962
c130aviator's Avatar
Which would u use? Cometic with 051 thickness or stock headgasket. I pulled my head to get some more work done and to install supertech springs. I ordered the cometic and then heard it leaks, so i bought a stock one just to be safe. what do u guys think? oh and i also had my lsj head milled a thousandth. Wondering if my compression would be 9 :1, with the cometic
Old Oct 19, 2012 | 01:09 AM
  #2963
InfraRedline's Avatar
I wouldnt so much call it "ordering", but rather pulling your spare tire out and putting in on one side and stealing someone elses and putting it on the other I keed I keed
Old Oct 19, 2012 | 02:06 AM
  #2964
BlkWdoSS's Avatar
if you are going to run the cometic, you need to deck the block and head, get it flat. The reason a lot of ppl have had issues with them is they try to install it without checking to see if the deck is flat so of course it will leak.
lolz thats how I run skinnies... and your car is badass in the pic.
Old Oct 19, 2012 | 10:12 AM
  #2965
SCcobaltSS's Avatar
I decked my block and my head when I built it and my cometic blew. I run stock now and wont go back.
Old Oct 19, 2012 | 02:03 PM
  #2966
IonNinja's Avatar
I have had a Cometic on my car for years now. I never had any issues but I'll be going back to stock once I tear my motor open again. I think stock should be fine. Why such a thick headgasket?
Old Oct 19, 2012 | 04:09 PM
  #2967
I figured after having the head and block decked(milled) it will make up for the loss of metal and it will lower my compression a bit more. I found that if you run .025 more than the stock HG it will lower compression about .5 points. So With this head gasket being about .24 thicker than a stock head gasket. I will see about 9:1 compression with my 9.5:1 forged pistons.
Old Oct 20, 2012 | 03:58 AM
  #2968
BlkWdoSS's Avatar
Im gonna be running a stock one for a while, we will have to see how long til I pop it lol
Old Oct 20, 2012 | 03:06 PM
  #2969
SCcobaltSS's Avatar
It wont pop. They are multi-layered just like cometic and I feel the same quality.
Old Oct 20, 2012 | 06:44 PM
  #2970
cylinder sleeve will fail before the hg will
Old Oct 20, 2012 | 09:56 PM
  #2971
nwss's Avatar
I've been on the cometic for 9 months and its just fine.
Old Oct 20, 2012 | 10:53 PM
  #2972
nwss's Avatar
Does the Zzp turbo swap come with a oil pan with bung for the oil line or does it have to be welded onto my original one ?
Old Oct 20, 2012 | 11:15 PM
  #2973
MP Cobalt's Avatar
comes with a bung to weld into the stock oilpan and oil return, and drain lines and dip stick. I ordered the oilpan off there site when i did mine.
Old Oct 21, 2012 | 02:27 AM
  #2974
rivaladore's Avatar
Yup that's one thing people have to keep in mine when ordering the kit. You have to take your oil pan off and drill/ weld their bung on. Good thing I bought an oil pan with a bung already welded from Frew on here before I ordered their kit. I think I have an extra zzp bung and oil feed line if anyone needs it as well as my lsj stock oil pan if anyone's interested
Old Oct 21, 2012 | 09:27 AM
  #2975
MP Cobalt's Avatar
hahah bought it off Frew huh. That's my buddy lol were going to ZZP here in November getting my car in house dyno tuned no more can tune and going to be talking to matt about my motor build plans
The only issues I ran across is when I ordered there oil pan they offer on the site and the dip stick never met up with the bolt on the intake manifold so it's zip tied (lame) I'm going to bring that to there attention while I'm there also I want it right so i can check my oil a lot easier than I am now.
