Official Turbo LSJ thread!!!
Old Apr 14, 2012 | 08:49 AM
  #1951
BLAZIN07SS's Avatar
I'm too JDM for you
Gonna set it up on 25psi and 20 degrees of timing. We'll see what happens
Old Apr 14, 2012 | 08:52 AM
  #1952
FrossB's Avatar
Thread Killer
Im thinkin over 450 then haha
  #1953
startingline05's Avatar
Sounds like a good start
Old Apr 14, 2012 | 09:39 AM
  #1954
BLAZIN07SS's Avatar
I'm too JDM for you
Yep, I can't get this gmpp clutch to slip either. Lol
Old Apr 14, 2012 | 09:41 AM
  #1955
mexi_loco's Avatar
that's what she said
Old Apr 14, 2012 | 11:39 AM
  #1956
rivaladore's Avatar
Nice to know ill probably throw that in there when I need a new clutch. So far my stock clutch is holding great on 20psi. Once I get a new clutch BYT is gonna up the boost and make my tune more aggressive, but even on this conservative tune the car feels like a beast.
Old Apr 14, 2012 | 12:13 PM
  #1957
yellowss7590's Avatar
i got the zzp stage 4 in both my cars now lol it holds up pretty well and blazin where did you get the 1000 injectors? my 80's are almost maxed -___-
Old Apr 14, 2012 | 12:45 PM
  #1958
zrated89's Avatar
Gmp>all others clutch is beast price is cheap.
Old Apr 14, 2012 | 01:51 PM
  #1959
BlkWdoSS's Avatar
Where did you get the ID1000s? and how much? looking at ID2000s but not wanting to drop $1k on injectors yet lol
Old Apr 14, 2012 | 03:14 PM
  #1960
EXsoccer1921's Avatar
stu pulled a 1.7 60' on the gmpp clutch back when he went 12.7s. definitely an amazing clutch for how cheap it is.
Old Apr 14, 2012 | 03:19 PM
  #1961
zrated89's Avatar
I've pulled a lot of 1.7s myself clutch won't miss a beat
Old Apr 14, 2012 | 10:03 PM
  #1962
slickss24's Avatar
Ok guys need help deciding between a s252et or s256et I'm looking for 400 to 450 with a fairly quick spool I don't want a laggy turbo I had a s20g so anything is an upgrade
Old Apr 14, 2012 | 10:27 PM
  #1963
brideout_8's Avatar
I have ordered my swap from zzp and had a question. As far as fuel considerations I was thinking about the BRFPS. But as I read through this thread I am not sure that is the best way. Do I need to do anything to the fuel system? And if so what would be the best route? I am getting the 252et and planning on 400.
Old Apr 14, 2012 | 11:01 PM
  #1964
slickss24's Avatar
Anyone? I wanna order this tonight but need some insight
Old Apr 14, 2012 | 11:10 PM
  #1965
BLAZIN07SS's Avatar
I'm too JDM for you
The s252 can get you to 400 and spool really fast. S256 has more head room for later mods
Old Apr 15, 2012 | 12:17 AM
  #1966
slickss24's Avatar
i have a built bottom end already but a stock head so u think i should go with the 252? and whats the differance in extended tip and not. and .55 ar and .70ar that are the options on zzp site
Old Apr 15, 2012 | 12:40 AM
  #1967
rivaladore's Avatar
My tuner has tuned both the s252et and the s256et. Told me the s256et pulls great in the top end and isn't that laggy and I should've gotten that turbo. I would've if I talked to him before I bought the kit but I was concerned with lag. But even on my very conservative tune and lower boost on my s252(I asked for it while I'm still on the stock clutch) it still has some big old *****, definitely happy with the s252et. Must be zzp's favorite turbo build for a reason, so their site says.
Old Apr 15, 2012 | 12:54 AM
  #1968
slickss24's Avatar
my only thing is i have a built bottom end 80# injectors and spec six puck unsprung clutch so i got just about every base covered so i wanna push this thing to the limit with still being able to dd
Old Apr 15, 2012 | 12:55 AM
  #1969
Billig ss/sc's Avatar
The s256et WILL have more lag than the s252et because it's a bigger turbo. My s252et definitely lags, but it isn't too bad. If you're just looking for 400-450 I would go s252et.
Old Apr 15, 2012 | 12:59 AM
  #1970
slickss24's Avatar
yeah i understand what ur saying but if the car is capable of more then that i wanna do it and i dont wanna run out of power with the 252
Old Apr 15, 2012 | 01:06 AM
  #1971
If you're looking for high whp, and go s256et make sure you do some research on building the engine first. I'd hate for someone to buy a bigger turbo for the most possible horsepower just to have it pop.
Old Apr 15, 2012 | 01:14 AM
  #1972
jonnymerk's Avatar
Anyone know more info on the hpt tuning tables involving the a/c and idle. my cars idle acts up sometimes when the a/c is running and I'm coming to a stop. my tuner said something along the lines that hpt didn't have a file or adjustment for this. Also do we have any MAF options over stock atm? I need to do something about my MAF as far as tuning for more boost. My tuner said I could run a 3.5inch tube as a probable solution to my MAF limitations. I wish he was here cus some of the stuff he knows is so far over my head and I'm sure he would be able to explain it better lol.
Old Apr 15, 2012 | 01:27 AM
  #1973
slickss24's Avatar
i already have a built bottom but idk i guess im just gunna get the 252et and hope im happy with it
Old Apr 15, 2012 | 01:43 AM
  #1974
jonnymerk's Avatar
how built is your bottom end? if I were to go beyond 400whp which many will say the stock bottom end can take if tuned properly, then I'd build my motor to handle at least 500whp and go with the 256et. I'm runnin an ebay 60trim turbo and with a few more pounds and some fuel mods Im hopin to hit 400whp. Id go with the 256 but that is my preference.
Old Apr 15, 2012 | 01:51 AM
  #1975
slickss24's Avatar
Diamond racing pistons total seal rings pauter rods arp headstuds and rod bolts and mls headgasket
