Official TVS Thread!!!
diamond pistons hardened rod bearings stock everything else in the block. GMR head, 78 lb supertech duals with Ti retainers, LNF Rockers, upgraded tensioner, four port single pass, tvs, 2.9 stock redline air box and filter, wrapped in silver insulation materia; zzp long tube header, egt probe .5 inch off # 3 exhaust port, trap door oil pan.
egt doesnt rise fast enough and afr the same to help you against runaway detonation on a turbo, but it is a useful tuning tool and an advisory that you are going too far one way or the other. I also enjoy watching the differences in egt according to air density on a day to day basis...
I've driven lsj's that drop off ,im taking about my setup and why it doesn't feel like it drops off.I've just noticed on lsj's I would usually see boost drop on the top end but mine rises.
as far as I know, its not simply a case of adding cooling or a ported head or cams; the blower cant deliver; it goes out of its efficiency range as the revs go over 6500 . check the compressor map for more details?
#3 or #4 are the troublesome cylinders. #4 its too difficult to package the probe around the t stat and the heater hoses. #3 does the job.
