Official TVS Thread!!!
Old Mar 3, 2013 | 01:47 PM
  #4801
InfraRedline's Avatar
I have a friend with nitrous on his cobra...$60 for a decent night of racing lol but its cheaper for now than him buying a SC or turbo setup. To each their own.
Old Mar 3, 2013 | 01:52 PM
  #4802
advise's Avatar
think i found the root of my problem
is it possible that my springs binding on the head casting is causing it to flex the spring at an angle and the rocker then hits the retainer
need help get new reatiners or go for the new supertech 75lb springs
Old Mar 3, 2013 | 01:57 PM
  #4803
advise's Avatar
heres a thread about someone seeing the springs contact the head
https://www.cobaltss.net/forums/2-0l...inside-255190/
Old Mar 3, 2013 | 03:35 PM
  #4804
mrbelvedere's Avatar
that is a common problem all you need to do is relieve the head as for the retainers I would just smoth them out and roll with them
Old Mar 3, 2013 | 04:01 PM
  #4805
advise's Avatar
Mrb you think the clearance in the pocket is causing my contact on the retainers?
Old Mar 3, 2013 | 04:06 PM
  #4806
zrated89's Avatar
i know the older supertechs had that issue where the head had to be clearanced
Old Mar 3, 2013 | 04:07 PM
  #4807
advise's Avatar
Is that the root cause of my rocker retainer contact
Old Mar 3, 2013 | 04:16 PM
  #4808
Powell Race Parts's Avatar
good post and info Advise, I stand corrected. I wonder what the age of the heads are; could be casting issues, could be supertech specs are out but based on what I know I would bet supertech are the same as they ever were. Worth a call to ask I suppose they are very helpful there. Cmiller clearanced his LNF head and I imagine you could do the same thing... the LSJ guy doesnt indicate any issues with retainer contact?
Also I ran supertechs since 2007 never had an issue before or since, other than LNF rocker contact most recently.
Old Mar 3, 2013 | 04:22 PM
  #4809
advise's Avatar
I think that the clearance issue is causing the spring to bind under high rpm causing the rocker to contact the retainer
Old Mar 3, 2013 | 05:07 PM
  #4810
we measured the contact of the rocker to the retainer. its in contact with the valve closed.
Old Mar 3, 2013 | 05:32 PM
  #4811
advise's Avatar
what should the clearance be ?
and obvious you'd measure it with the cams installed
Old Mar 3, 2013 | 05:39 PM
  #4812
So the one I bought comes with a 2.6 ....
80s and brfpr needed? Also currently I'm spraying water meth pre blower. Is this still ok with tvs or not recommended?
Old Mar 3, 2013 | 05:46 PM
  #4813
100% METH's Avatar
If you're on 91 or greater, water/meth and 80s are all you need on a 2.6
1000s & reg. is recommended if you run e85 using that pulley.
Water methanol is safe to use with the tvs. Coating and destroying needle bearings are nothing more than wives tales.
Old Mar 3, 2013 | 05:52 PM
  #4814
Ill take that 2.6 off your hands lol
Old Mar 3, 2013 | 05:53 PM
  #4815
100% METH's Avatar
Want mine Taylor? I dont plan on using it.
Old Mar 3, 2013 | 05:54 PM
  #4816
All I need is 80s and a retune and larger nozzle? Sweeeet.
I've already proved 50k miles worth of meth pre blower does nothing to coating despite what others have said. But I'm sure you already have fought those battles as well lol.
Where's the best place to pick up 80s
Old Mar 3, 2013 | 05:55 PM
  #4817
Oh, also run 93 shell only in her
Old Mar 3, 2013 | 05:58 PM
  #4818
100% METH's Avatar
Nearly tripled... 126k through mine.
Zzp
Old Mar 3, 2013 | 06:34 PM
  #4819
meth will seize your bypass eventually. its not needed and a pita in my opinion.
anything over 300 on these fwd cars is a waste of gasoline and tires lol
Old Mar 3, 2013 | 06:53 PM
  #4820
Bluelightning's Avatar
Got Bewst?
Talk to Josh at OTTP too for 80's. He's always good for deals.
  #4821
574's Avatar
574
I'll sell you my 80's in a couple weeks. They are zrateds 12.0 injectors, that ups the value right...?
Old Mar 3, 2013 | 07:06 PM
  #4822
574 keep me in mind for sure! Orings and Harness too?
Old Mar 3, 2013 | 07:10 PM
  #4823
574's Avatar
574
Yeseh. Getting the 1000's so I am gonna be modding my stock harness
Old Mar 3, 2013 | 07:22 PM
  #4824
armcclure's Avatar
That's why I plan on running a solid motor with te m62 on top. Once I'm done dynoing, pull it back to 300 motor and keep the happy juice for high speed encounters
On the track of course.
Old Mar 3, 2013 | 07:34 PM
  #4825
advise's Avatar
Beat me to it lol, keeping my springs so injectors may be purchased this week
Just gunna mod what I have with new retainers
