Official TVS Thread!!!
#5583
Killer chiller uses AC. I asked CryO2 they said praxair or AirGas, neither of which we have around here.
Edit: just found an AirGas not too far away. Hooray! Let the testing begin...
#5589
if i remember correct that flatgod did something to his intake manifold to make his killer chiller more effective.... the kit is only a starting point...... not a 100% sure about this tho.... it was a long time ago......
#5590
Yes. A/a + w/a. KC is the only thing the w/a section goes through.
Eric ill look I to that. My guess would be stores jack up the price because soda stream nuts don't know any better...
#5592
#5593
quick question guys. is it pretty common to have belt slip with a 2.75 inch pulley and the stage 2 belt? i just put the smaller pulley on (down from the stock TVS 80mm pulley). when i am driving normally it is fine, but the second i try to get into it (more than about 12 psi) it has a god awful squeal. got my dad to look at it when i rev it and he said it looks like the belt has a bit of slack when i blip the throttle.
im guessing i need the bigger tensioner pulley.
am i on the right track?
#5594
I can't say I've ever had slip with my 2.7". I thought I did and added the oversized tensioner with the stage 2 belt and boost came on the same so I guess it wasn't after all. But still run both.
Make sure the belt is sitting on properly on all pullies. That can cause squeal as well.
#5595
#5599
Soda maker. You carbonate water using CO2 and then add soda concentrate.
Sodastream | Turn Water Into Fresh Sparkling Water And Soda
