Prototype Intake manifold
So this winter I had an extra LIM and extra time so I decided to try something new. So as far as description goes it's a air to air and water to air LIM. 2.5" inlet/outlet. I converted it to single pass as well and opened up the laminova ports to 19mm. I will be using a killer chiller unit as the sole cooler of the fluid for the laminovas. For ppl wanting result your going to be waiting a while, car is parked till spring. So flame away and in 3-4 months I'll post results.
interesting... sub'd for results.
did you block off the air coming from the supercharger so that it ONLY goes through the air/air and then through the air/water? do you have shots of the inside, particularly where you opened the laminova cores?
It works by increasing the amount of oxygen in the system which burns completely with the fuel. If the car is very hot, it will bring a condition where the people in there will be uncomfortable. This therefore means that they will not enjoy their time like they would wish to.
k&n cold air intake
k&n cold air intake
k&n cold air intake
k&n cold air intake
