Official TVS Thread!!!
Old Aug 5, 2013 | 09:02 PM
  #6376
Powell Race Parts's Avatar
^^selling tickets? lol
Old Aug 5, 2013 | 09:03 PM
  #6377
06blackg85ss's Avatar
^^^ agreed. It hydraulic'd. Prolly cylinder got filled with too much fuel. He saw 10.0 a/f. does the gauge read lower?
aem nope
Old Aug 5, 2013 | 09:04 PM
  #6378
free videos are better lol.
gonna have to use mikes beater vette as the cam car probably as my car definitely won't keep up.
Old Aug 5, 2013 | 09:35 PM
  #6379
JapEatr's Avatar
South Central *********
Battery light came on after hard pull to 8k, think i could have killed alternator over reving.
The alternative is grimm
Old Aug 5, 2013 | 09:36 PM
  #6380
dwarrick's Avatar
??? actuator has two nipples. The solenoid is beside the rocker cover, has three nipples. lower front to atmosphere; upper front to IM. rear nipple to actuator on TVS. second nipple on TVS actuator goes to blower nipple.
Solenoid has one going to the IM, and the other has the little foam filter to the atmosphere. It is the other side that is messing me up.
The actuator has the larger hose goes between the end of the actuator and then to the side of the TVS.
It is the other end of the hose from the solenoid that I cant find. It hidden pretty good but I cant find the nipple on the actuator that it should go on. Could I have the wrong actuator installed? Is there an actuator that doesn't have that nipple for the hose from the solenoid?
Old Aug 5, 2013 | 10:17 PM
  #6381
not that i know of. how can an actuator work without two hoses? it cant. take pictures or something.
Old Aug 5, 2013 | 10:19 PM
  #6382
uh oh....
Old Aug 6, 2013 | 01:46 AM
  #6383
RooTBeeR's Avatar
this means scientific stuffs haha
Old Aug 6, 2013 | 08:48 AM
  #6384
Verbatim's Avatar
Figured Id let you guys know how mine is doing.
With the 2.6" pulley, we are having trouble with the meth spraying so much so fast its causing KR. But this 2.4 loves the boost, Even with some KR, running 10:1, and only 17-18deg it feels like its between 330-340hp and 300tq
We have only done 3-4 WOT passes, his laptop shutdown on him...So tuning more this week as long as the weather holds out.
I do need a new boost gauge tho I believe; Over 15psi, the gauge bounces rapidly between 15psi and above 20psi. If you use the MAP/external gauge, there is no bounce. And since it only reads max of 20, I needed a new one anyways.
Its such a cute little LE5
Old Aug 6, 2013 | 08:50 AM
  #6385
armcclure's Avatar
Yay kr...
Old Aug 6, 2013 | 08:54 AM
  #6386
100% METH's Avatar
With the 2.6" pulley, we are having trouble with [b]the meth spraying so much so fast its causing KR.[\b] But this 2.4 loves the boost, Even with some KR, running 10:1, and only 17-18deg it feels like its between 330-340hp and 300tq
Say what?!
Sounds more like you have either to little or to much fuel on tip in.
Could you be more specific?
Old Aug 6, 2013 | 09:09 AM
  #6387
Tjolley's Avatar
Is that a stock Le5 bottom end?
Old Aug 6, 2013 | 09:17 AM
  #6388
Tjolley's Avatar
I would think u would be closer to 400 hp with a 2.6
Old Aug 6, 2013 | 09:19 AM
  #6389
Bluelightning's Avatar
Got Bewst?
Guess I'm lucky getting no knock running a 14gph nozzle with my 2.6" lol
Old Aug 6, 2013 | 09:22 AM
  #6390
Verbatim's Avatar
It runs and drives great(got a weird blower surge thats sporadic) But once the meth kicks in(8-10psi) it just hits bout 4-8deg of knock. I got the progressive controller set at sparting at 8 and full in at 11. I have since changed it to 5 starting and 16 full.
But its definitely running fat; At 5800 yesterday I saw 10.0 then 3 dashes...so ya, shes a little rich.
DW300, LSJ rail, 80s, fuelab regulator boost ref, full -6 return, and 2 7gph 50/50(by volume)
This is all new ****, and we are just taking our time. We are in no rush; Although I do daily it, I have enough self control to stay outta boost.
And yes Tjolley, stock lower end. built p&p head with studs tho...**** it, it'll be good
Old Aug 6, 2013 | 09:25 AM
  #6391
Verbatim's Avatar
going from stock fuel system(other than 60s), stock engine, and 3.15" pulley to all the **** I got going on now...We only have about 3 hours into the retune so far, and 2 hours of it was driveability ****.
But it feels good, its gonna make some power when fully tuned, and my 15" dr-33s for my ET streets came in yesterday
Old Aug 6, 2013 | 09:46 AM
  #6392
InfraRedline's Avatar
Quit doing pulls if its that rich, and if you are getting that much knock. Other than that, it should be pretty cool when its finished. 2.4 TVS goodnees.
Jap, you're scaring me.
Old Aug 6, 2013 | 10:03 AM
  #6393
dwarrick's Avatar
I thought the same thing. Only thing I can think of is the nipple snapped off sometime during the install. Ill take it back off to investigate.
Will the M62 one work if the TVS one is damaged, or are they 2 different designs?
Old Aug 6, 2013 | 10:18 AM
  #6394
robertmichaels's Avatar
It should have 2 vacuum hoses just like the m62 does, the hoses should go to the same point
Old Aug 6, 2013 | 10:25 AM
  #6395
Verbatim's Avatar
I baby this guy; I stay under 8psi as much as possible anyways. The only "pull" ive done outside tuning, was 1 pull Sunday evening when some ******* wouldn't let me over on the highway
It did great with the 3.15" pulley, can't wait to get some numbers
Once it's all squared away
Old Aug 6, 2013 | 11:12 AM
  #6396
I was spinning to 9600+ rpm and the alternator is still going stong in another car spinning 8k rpm. Maybe just belt slip?
Old Aug 6, 2013 | 11:24 AM
  #6397
JapEatr's Avatar
why? if your scared ill buy you a dog...
Old Aug 6, 2013 | 11:33 AM
  #6398
Excuse my earlier post, as I'm beyond tired today. My thought was that maybe the keyway broke and that the belt wasnt spinning the alt. and thats why the battery light came on. Then 10 minutes later I thought about it again and realized that if that conclusion even entered my head then I'm in no condition to be putting thoughts together today
I would not turn down le dog though...lol
Old Aug 6, 2013 | 11:46 AM
  #6399
JapEatr's Avatar
**** now im scared... i hadnt thought about that... my grimm thoughts were that i snagged a wire drilling holes for my roll cage and had a short
cus pulling that cage back out is a MF'r
Old Aug 6, 2013 | 01:03 PM
  #6400
ThexGovenor's Avatar
my fuel filter is leaking like a sieve. lost 3/4 of a tank in like 15 minutes. New one is on the way. I guess no driving for a while.
