Official TVS Thread!!!
#6401
Just stop and think what would happen if the belt stopped moving, then reread infras post
#6403
#6405
South Central *********
Alan... Lol i got it, at the time i knew it wasnt that because the ac still worked and had boost.
But my point was even if i sheared the crank key way, the damper is pressed on, it wouldnt spin in place
I think the alt may be on the outs or my Volt meter is wrong by a couple volts
I showed 11.6V when i put it on the battery posts with car running
#6411
Ya i pulled steves off
Have to take the engine mount loose to get the dampaner off.
T40 and T45 torx socket needed
Then used a pulley puller or somethin to pull the hub off.
#6420
^^ This. I damaged a thrust bearing on the crank in my old motor putting the ATI on with a hammer. I didn't whale on it either, just slowly tapping it in.
#6421
I used a heat gun and heated the middle where the crank slides on for about 5 min. The ATI slid on about 50% of the way then I just used the crank bolt for the rest. Makes it much easier knowing you are lining everything up before cranking it down with the bolt.
#6422
Im down
Swaping a head is easy. Couple hours.
Ask steve we had his head off in proly 2 1/2 hrs and that will taking a pizza break. Lol
Can be done faster with out interuption.
