Official TVS Thread!!!
Old Aug 11, 2014 | 11:32 AM
  #9076
jonathan923's Avatar
sucks i left right before the fireworks after been there all ******* day haha. chris's balt is going to be a beast though
Old Aug 11, 2014 | 11:35 AM
  #9077
RooTBeeR's Avatar
Originally Posted by 06blackg85ss
at full pump pressure it was 70gph (300 psi with a 30 and 25 gph nozzles) and we've already tested the meth theories on my buddies 1300hp twin turbo corvette with astounding results, so why not try it on a cobalt
as for actual boost, well gauge read to 30psi and it was coming back around (between the b and the o "boost" that was labeled on the bottom of the gauge lol)
70gph... so the IDC's were at 30-40% on stock injectors?
as far as the boost gauge goes
Originally Posted by Empty Pockets
my TVS pulls hard at ~23psi... 35+psi must be nuts
I only ever saw 23psi on the 3.15" and it pulled decent, but i never had much timing in it.
Old Aug 11, 2014 | 11:39 AM
  #9078
Staged07SS's Avatar
Administrator
Administrator
thats on the way in a little bit bigger and badder package. 550-600whp out of a tvs just might be possible
but yeah I've never heard a tvs scream like a banshee until that night lol. That ****** was hauling.
and I knew it was gonna blow up, even told him it would. But damn I've never had a sc cobalt run that hard before. the spin out in the oil at the end kind of sucked though
and technically at full pump pressure it was 70gph (300 psi with a 30 and 25 gph nozzles) and we've already tested the meth theories on my buddies 1300hp twin turbo corvette with astounding results, so why not try it on a cobalt
**** it at least someone had the ***** to try something new and not build the same **** that has been done over and over again on here.
  #9079
06blackg85ss's Avatar
yeah jonathan you should have stayed, and chirs's car is a monster and a half at 26.4 psi too bad fuel system is maxed the f out though. New setup in the works and 40+psi to come on that beast.
Old Aug 11, 2014 | 11:42 AM
  #9080
lol idc was down to about 71% on the id1000's at 7915 rpm the pull right before the last and final one.
but according to a few calculations we did (going off whatever harrop data we can find) blower outlet temps should have been approx 520 degrees, we were seeing a peak of 221 deg iat2's (still too high for my liking) so meth was definitely doing it's job somewhat.
But we have a few things in the works to fix these issues and get this thing making some serious hp on the tvs. You know how much I hate supercharged 4 cylinders, so it's gotta be something seriously balsey to get me to want to work on it lol.
on another note the 6262 car was seeing a peak of 77degree iat2's at 26psi and definitely over 500whp lol.
Old Aug 11, 2014 | 11:44 AM
  #9081
just to give you an idea of what that sounds like quick little 2nd and 3rd gear pull, trans is acting up so he's shifting slow (he mess it up when doing the lsd)
Old Aug 11, 2014 | 12:08 PM
  #9082
advise's Avatar
Ill be back built with custom cams
it was a fun death my 100 to 120 was faster then a c6 z06
And that whine
Nothing like hearing the block bounce off the car
Sounded like glass being ran over haha
Old Aug 11, 2014 | 12:12 PM
  #9083
RooTBeeR's Avatar
Old Aug 11, 2014 | 12:14 PM
  #9084
And that whine
you got that right lol
Old Aug 11, 2014 | 02:37 PM
  #9085
Area47's Avatar
Rent me! per hour
the tvs will scream if you wind it tight enough.
Old Aug 11, 2014 | 02:49 PM
  #9086
InfraRedline's Avatar
This is just ridiculous lol. At least it was fun while it lasted I guess
Old Aug 11, 2014 | 02:58 PM
  #9087
RooTBeeR's Avatar
Wait, wtf? Since when are you faster than Bob White???
Old Aug 11, 2014 | 03:31 PM
  #9088
mrbelvedere's Avatar
I think spraying e85 instead of meth would have been a better choice
Old Aug 11, 2014 | 03:55 PM
  #9089
SSfamilywagon's Avatar
I think it was awesome. Glorious death!! You knew the outcome when you made the decision. Glad to see someone at least try a different thing to cure their own curiosity. I'm tired of the how should we say cookie cutter builds because its safe to do so.
Old Aug 11, 2014 | 04:26 PM
  #9090
advise's Avatar
How so meth as better cooling properties and a higher octane
Meth didnt do.it cylinder pressure did
Old Aug 11, 2014 | 05:11 PM
  #9091
you might want to do a little more reading on that not to mention you can use a fuel injector to get better atomization or you can use a nitrous fuel solenoid
Old Aug 11, 2014 | 05:12 PM
  #9092
Area47's Avatar
Rent me! per hour
Since no one gives a ****.
Old Aug 14, 2014 | 09:53 AM
  #9093
100% METH's Avatar
400 psi progressive solenoid - 4AN
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251573662256&ssPageName=STRK:MESE:IT
300 psi progressive solenoid - 4AN
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251573664129&ssPageName=STRK:MESE:IT
Old Aug 14, 2014 | 06:31 PM
  #9094
Blairwolf's Avatar
My stock camshafts got mixed up. How do I tell which is intake and which is exhaust. One has a 10 and the other has a 2 on it. Is it really that simple? 10 is exh and 2 is intake cause thats how the gears go when you time it, or is this just a coincidence?
Old Aug 14, 2014 | 06:48 PM
  #9095
the intake cam last 3 of the part number is 985 the last 3 of the exh cam is 363
Old Aug 14, 2014 | 07:02 PM
  #9096
Blairwolf's Avatar
Coincidentally the 10 is the exh and the 2 is the intake. Thanks MR.B
Old Sep 13, 2014 | 10:57 AM
  #9097
Verbatim's Avatar
Aiight guys; havent been around for a while, but finally got a good solid tune on my shitbox.
But here is the problem; last year around july I had Steigemeir rebuild my TVS cause the needle bearings were going out, about 20K miles on the blower with a 3.1 pulley and 14gph meth.
Well last week it started making the case needle bearing noise again right after I popped the 3rd bypass valve apart...the bypass valves either blow the diaphragm apart or the spring breaks.
Im currently on the 2.6" with 14gph and I just swapped nozzles to 24gph, but ot doing anything since the ****** wont boost...
My questions is: I havent really heard anything about other guys having these consistent issues like I am, wtf is the deal with my pileoffuck?
And I dont have the cash right now to have it rebuilt so Im gonna just throw a new set of needle bearings in, but are the bearings the same as the m62 or wut?
I have my buddy Brian K giving me a hand with the rebuild btw, (100%meth and trevor knows him)...
Old Sep 13, 2014 | 11:05 AM
  #9098
either your not getting enough grease in the needles or the bearings got damaged upon install or something happened to the rotor pack and it is out of balance or could be out of time also
Old Sep 13, 2014 | 11:24 AM
  #9099
Verbatim's Avatar
if I can track down what needle bearing it is and I can get some coming, Ill rip that bitch apart and take a look see.
Old Sep 13, 2014 | 12:05 PM
  #9100
TStone's Avatar
the blower????
....... or the engine?
