Official TVS Thread!!!
Old Dec 5, 2014 | 10:59 AM
  #9426
Staged07SS's Avatar
Administrator
Administrator
My head dropped me about 3 lbs. I saw about 16 lbs on the 2.9 and 19lbs on the 2.7 IIRC. With the cams I saw 19 falling to 17 on the 2.9, 21-22 falling to about 20 up top on the 2.7, and 24 falling to 21 on the 2.6. The boost curve changed as well, as you could see on my old TVS dyno graph. Instead of being linear it caused a peak and fall effect.
Hmm.... what was the reasoning your boost fell off?
On my car it builds and peaks right at my rev limit. Never falls off.
Old Dec 5, 2014 | 01:16 PM
  #9427
armcclure's Avatar
Taylor you talking about my set? If so that's realy odd because I lost about 1/2 in the midrange and 1-1.5 up top.
Old Dec 5, 2014 | 02:18 PM
  #9428
InfraRedline's Avatar
Yeah mine started falling off when I put the cams in. It boosted more than the stock cams, so that threw me off. I thought maybe the huge head ports and cams together were outflowing the blower on the 2.6, but it did the same thing on the 2.9, so I'm not sure. It used to peak at redline. On the m62 on the gray car it does the same thing, but I don't know if that little guy can keep up with the airflow.
Yeah the set I got from you. Car ran well, it just dropped boost up top and made more boost than the stock cams! Always baffled me lol.
Old Dec 5, 2014 | 03:09 PM
  #9429
JapEatr's Avatar
South Central *********
Wonder if the bypass valve wasnt holding shut
Old Dec 5, 2014 | 03:28 PM
  #9430
It was. I tried literally everything mechanically. Tried 3 different bypasses, tried adjusting the valve on the blower, did the bypass mod, boost leak tested it probably 20 times, changed blower gaskets, everything. And it didn't do it in spring when the stock cams were in it, but after I did the cams it started dropping boost up top. After all that I just said screw it because the car ran hard and pulled well, so I didn't bother trying anything else. Still doing the same thing with the M62 which is now the 4th bypass valve, but still the car runs hard. 13.0 with a 1.96 60' through the stock catback on a 2.7 M62, she's healthy enough.
Edit: And that same TVS is on my friend's car now and making 24 lbs up top on the 2.7 on the stock head and stock cams with a linear boost curve. So I know the blower is working correctly.
Old Dec 6, 2014 | 12:21 PM
  #9431
Blairwolf's Avatar
Can anyone tell me if I should install a new balance shaft chain kit when I install the neutral balance shafts? My car has around 90k miles on it.
Old Dec 6, 2014 | 01:58 PM
  #9432
mrbelvedere's Avatar
i would
Old Dec 6, 2014 | 02:45 PM
  #9433
TStone's Avatar
Doesn't hurt. Another not so bad idea would be the waterpump too while you're in there.
Old Dec 10, 2014 | 05:18 PM
  #9434
advise's Avatar
As some of you know I blew my motor back in July
Current mods in Sig with a 2.3 pulley and ati plus 55gph of meth
Well I'll be back shorty
I have all the parts just need to get it machined and then slap it together
Here's the break down
Gen 3 block
Custom diamond 88mm 10.5:1
Pauter rods
Stock crank micropolished
Ati
M2 cnc head
Ferrea 1mm o.s valves with 30° back cut
Supertech 75lb springs
New OEM guides
Ottp stage 4 cams
Tvs 1320 with a 2.3 pulley
Ais trunk mount dual nozzle
Snow performance controller
Nitrous express 15lb proton kit
Remote opener, heater,purge, fuel pressure switch, progressive controller and window switch
100 shot for the norm. 200 for kill mode
Old Dec 10, 2014 | 05:21 PM
  #9435
Sleeves?
That sounds awesome. So many killer blower builds lately! Almost sounds worthy for a 1900...
Old Dec 10, 2014 | 05:41 PM
  #9436
advise's Avatar
Nah
Has anyone cracked one ?
Old Dec 10, 2014 | 05:48 PM
  #9437
Bluelightning's Avatar
Got Bewst?
Why so much meth again?
Old Dec 10, 2014 | 06:20 PM
  #9438
Josh@ottp's Avatar
Gen 3 block
Pauter rods
Ati
M2 cnc head
New OEM guides
Ottp stage 4 cams
Be a big boy. Spray what you make.
Old Dec 10, 2014 | 09:13 PM
  #9439
06blackg85ss's Avatar
Pill it til ya kill it.
Old Dec 10, 2014 | 09:39 PM
  #9440
yes sleeves have cracked lmaoo
my boost drops off a bit up top too
Old Dec 10, 2014 | 10:24 PM
  #9441
advise's Avatar
Cracked a gen 3
Old Dec 12, 2014 | 10:33 AM
  #9442
Rice I think you overlooked the Gen 3 part.
Old Jan 20, 2015 | 06:10 PM
  #9443
Well...
I just joined the TVS club. But shaeffers tvs with a 2.8.
So in the spring when i have my trans back on and all that im gonna go see al and slap it on.. probly get some 1200s and an aem320 from him while im at it
Hellooo 370ish Whp?
Old Jan 20, 2015 | 06:11 PM
  #9444
Gds rice
Old Jan 20, 2015 | 06:24 PM
  #9445
Lol
Old Jan 20, 2015 | 06:40 PM
  #9446
Got Bewst?
Nice! You're gonna love it.
Old Jan 20, 2015 | 07:24 PM
  #9447
TStone's Avatar
niiiiiiiice
Old Jan 20, 2015 | 07:28 PM
  #9448
574's Avatar
574
Hell yeah
Old Jan 20, 2015 | 08:42 PM
  #9449
It was bound to happen one day lol.
So idk looking at dyno numbers with somewhat similar numbers, its all across the boards.. i dont really have a goal here but looks like ~370/300 to the wheels is doable
MrB once i heard yours screaming behind me ripping the tires in 2nd gear at the meet this summer i just had to get one lol
Old Jan 20, 2015 | 08:52 PM
  #9450
Got Bewst?
Yup that's right around where you'll sit with your current set up.
