Official TVS Thread!!!
Same approach, but not equal.
Modern Methanol pumps in kits are rated for 300 psi and are pre set for 200-210.
Methanol stoich is 6:1 circa
58 psi at the rail
E85 requires less fuel with a higher stoich
So has it been figured out what's the best best set up to run while sc ? Dual pass or single pass with option b? Extra h.e or just the stock one moved to the front ? Really leaning to go TVS instead if a turbo swap already did that on my old ss and would like to try something different with my redline now ..
Not looking to run meth . Just e85
To make good numbers, run full exhaust, option B, dual pass, FMIC or griffin. Also a ported head does wonders, along with good cams. My build is in my sig. Im replacing my injectors with FIC 1200's though because the 80's dont keep up.
Griffins is a better replacement of the stock h.e right ? And yeah I have full exhaust . Dual pass. Opt b already and dw300 pump and 80s . Car supposedly had pistons and valves done from last owner
i havent looked at a gms3 t00n in forever, so i dont remember.
killer
wait for it
CHILLER!!!!
Triggered to come on at xrpm & throttle percentage, but not maf hrtz.
You're not a noob man. You know your stuff.
A ported head is a good time though
