Official TVS Thread!!!
Old Jan 27, 2014 | 01:41 PM
  #8126
advise's Avatar
So I pulled my valve cover too inspect my valvetrain and it looks like my rocker arms are hitting my retainers on my 75lb supertech springs
Switched from 78s to 75s to fix this problem
Dont know why I have bad clearance
Maybe when they cut my new valve seats for my .5mm valves they changed my stem height?
Works fine but I'm worried about dropping a valve if the retainer cracks
Old Jan 27, 2014 | 01:55 PM
  #8127
ThexGovenor's Avatar
thanks advise! Ill keep that in mind. Im also considering the 1200s that ARM runs. Looks like they idle well, and should flow enough for me regardless of my plans.
Old Jan 27, 2014 | 01:59 PM
  #8128
freakta's Avatar
Glad to see your project moving along.
Old Jan 27, 2014 | 07:27 PM
  #8129
mrbelvedere's Avatar
springs are generally designed with a stock spring install height but once you get to a certain point you will need to mod the head for springs
anytime you grind on the seats and valves you change the stem height (and spring instlled height) so it will stick further through the fix is measure the stem height from the top of guide to top of stem before you do the valve job and write it down or try to find the stock specs
now when you do grind on the seat or valves you re measure your stem height if its to tall then you remove material from the top of the stem so you put the follower geometry back to original height and by doing that the retainers should not hit the followers if they do then just grind a little off of the sides
to fix spring installed height you need to shim the bottom of the spring
Old Jan 28, 2014 | 10:35 AM
  #8130
advise's Avatar
Its odd because its only on the exhaust
So could I get away with only grinding my followers
So my spring height is to high or my stem height is so shallow?
Where can I find ecotec valve/spring specs
Old Jan 28, 2014 | 10:40 AM
  #8131
yup you can get away with it but don't go crazy
your stem height is what determines everything if its to tall(from grinding on seats and valves) then the installed spring height will be off because the stem is sticking further out which raises the retainer height and so on
Old Jan 29, 2014 | 09:49 PM
  #8132
Mendomar06's Avatar
Whats up fellas?
Old Jan 31, 2014 | 02:48 AM
  #8133
100% METH's Avatar
Nada Lata
Got the Tvs and stg3 cams on e85 now
2.9 pulley feels a little sluggish with these cams, puting the 2.6 on and 5th injector at the throttle body on this weekend.
Old Jan 31, 2014 | 08:32 AM
  #8134
Tjolley's Avatar
I told u, U wouldn't like how slugish that 2.9 will be with the cams!!!! Lol
Old Jan 31, 2014 | 12:10 PM
  #8135
Mendomar06's Avatar
Originally Posted by 100% METH
Nada Lata
Thats good bro, so I'm getting my taxes sometime next week. I can finally afford to get Hp Tuners (don't buy a house unless your sure you're ready for the responsibility )
How are those cams working out? I'm thinking of doing the NBS Delete and adding cams but I'm a little weary of it as the car has 89K miles on it and been running a TVS with a bad tune so I don't know if anything is damaged, it doesn't seem like it but what do I know.
Old Jan 31, 2014 | 01:39 PM
  #8136
RooTBeeR's Avatar
So needs more low end boosts?
Old Jan 31, 2014 | 01:47 PM
  #8137
Mendomar06's Avatar
It really doesn't need more boost, I just want to take advantage of the $2000 blower sitting in my engine bay.
Old Jan 31, 2014 | 07:10 PM
  #8138
Nada Lata
5th injector? try a 2.7 first
  #8139
RooTBeeR's Avatar
Sorry that was to steven
Old Jan 31, 2014 | 07:25 PM
  #8140
Mendomar06's Avatar
My bad bro^
Old Jan 31, 2014 | 10:29 PM
  #8141
100% METH's Avatar
I have a 2.6 on the shelf
It needs the 5th injector even on the 2.9.
@andrew
Yeah I miss the grunt of the 2.6
Can't wait to rev it out to 8k
By 7k with the ati/2.9 I'm seeing 19 lbs
Old Jan 31, 2014 | 10:35 PM
  #8142
@andrew
Never seen the 5th injector used with the LSJ. Would love to see the results. Have you thought about bigger injectors instead? Just out of curiosity.
Old Feb 1, 2014 | 01:45 AM
  #8143
100% METH's Avatar
Basically a fuel jet fed off the rail, solenoid, and boost switch.
It's similar to methanol injection except it utilizes the car'a fuel system instead.
Old Feb 1, 2014 | 08:37 AM
  #8144
sounds like part of a nitrous kit to me
Old Feb 1, 2014 | 11:15 AM
  #8145
noorj's Avatar
bringin back TBI lol
Old Feb 1, 2014 | 11:38 PM
  #8146
RooTBeeR's Avatar
Hey, nascar uses it lol
Old Feb 2, 2014 | 12:26 AM
  #8147
Tjolley's Avatar
It allows u to run small injectors and maintain good deivability and make a ton of power. It also cools the blower by having a liquid going through it and attempt to pull the heat out.
I messed with it in the past wen I ran NOS. Seemed to work well.
Steve should be able to perfect the tuning of it and show some good proof.
Old Feb 2, 2014 | 01:19 AM
  #8148
Just ordered some 1200s from ARM. Looking forward to tuning it and seeing what it makes on the dyno after I dial it in!
Old Feb 2, 2014 | 01:40 AM
  #8149
SPDDMN36's Avatar
Ill be ordering mine tomorrow now to decide if I keep these cams or not, might be more work than I thought.
Old Feb 2, 2014 | 03:16 AM
  #8150
Honestly GMR cams are work. I had drop in so I have no reference. But Ill for sure let you know how the 1200s are!
