Official TVS Thread!!!
Old Apr 20, 2013 | 11:40 AM
  #5626
LaserblueSS's Avatar
wow. didnt know the tvs was worth so much. i got mine for a deal last year if they are still selling for 1500 used.
Old Apr 20, 2013 | 01:11 PM
  #5627
InfraRedline's Avatar
Bored, so Ill post the cell phone pics I have of of my freshly painted goods. Need to get some pics when the engine bay isnt dirty and when I take the car outside in the sun. The VC and intake are pearl white with gold boat flake and red pearl in the clear (just look white in the pics) and the coil pack cover is gray from a 2007 Toyota Solara, close to the TVS color.
Old Apr 20, 2013 | 02:32 PM
  #5628
100% METH's Avatar
looks nice taylor
Old Apr 20, 2013 | 02:44 PM
  #5629
mrbelvedere's Avatar
looks good just need to get rig of that vented can and turn it into a closed system
Old Apr 20, 2013 | 03:14 PM
  #5630
Planning for the future
Old Apr 20, 2013 | 05:47 PM
  #5631
even with a snail it needs to be closed now if you were running a dry sump that would be different
Old Apr 20, 2013 | 07:29 PM
  #5632
Bluelightning's Avatar
Got Bewst?
I still don't see any big benifit from running a closed system vs vent to atmosphere
Old Apr 20, 2013 | 08:45 PM
  #5633
armcclure's Avatar
The reasons are out there. I'm not gonna get into the how and why. Powell has covered it multiple times along with others. Long story short, you need vac on the crankcase. Which only comes from a closed system.
Old Apr 20, 2013 | 08:51 PM
  #5634
Melon's Avatar
Never even thought about this. How much is it and how hard to implement?
Old Apr 20, 2013 | 09:13 PM
  #5635
advise's Avatar
Got my car tuned today ran into a problem with a idling
Hits 156temp and stalls, reflash and don't turn it off no problems
After it stalls on a warm restart it, runs choppy and sounds like its missing but no misfires and fuel trims go to zero and it runs full lean
Go do a pull after a fresh reflash, sold afr to 8k
Old Apr 20, 2013 | 09:21 PM
  #5636
100% METH's Avatar
Sounds like the car is going into open loop.
Old Apr 20, 2013 | 09:35 PM
  #5637
advise's Avatar
Thought that, but in the log the fuel trims just go to zero
Old Apr 20, 2013 | 09:56 PM
  #5638
100% METH's Avatar
They zero out normally when you enter open loop
Old Apr 20, 2013 | 10:12 PM
  #5639
JapEatr's Avatar
South Central *********
Open loop for sure
Old Apr 20, 2013 | 10:24 PM
  #5640
Got Bewst?
Can you point me towards any good links for some reading?
Old Apr 20, 2013 | 10:31 PM
  #5641
advise's Avatar
Originally Posted by JapEatr
Open loop for sure
What would cause that
Old Apr 20, 2013 | 10:35 PM
  #5642
armcclure's Avatar
No they don't. Scan from a cold start. Stft is zero ltft is not. "Learned" trims are there in ol too.
However, his trims may be going to zero in ol since this is happening after a fresh tune and it hasn't hat time to learn yet.
Old Apr 20, 2013 | 10:49 PM
  #5643
advise's Avatar
Drove for 40mins car idled fine small surge
Then next stop light went full lean and had a missing idle with no misfires being logged
Old Apr 20, 2013 | 11:35 PM
  #5644
armcclure's Avatar
What Injectors and where did you get the settings? Is this happening with new mods or just a new tune?
Old Apr 20, 2013 | 11:56 PM
  #5645
advise's Avatar
My tuner paul, just did the head cams and injectors, mods in my sig
Old Apr 21, 2013 | 02:57 AM
  #5646
ThexGovenor's Avatar
was it raining? just curious because sometimes when its raining mine will go retarded lean and want to die/not accelerate on me. Does going full WOT which should trigger the command Air Fuel ratio make it run right?
Old Apr 21, 2013 | 08:35 AM
  #5647
06blackg85ss's Avatar
I"ve got to do some digging, car is still commanding correct afr at idle. Infe's car does a similiar thing occasionally, but his will only do it for a few seconds and go back to normal. Never got a chance to figure it out since he decided to do a built motor and the cars been sitting for 7 months waiting on the machine shop.
This car goes into that, and just stays there. after a flash, car runs perfect, idles right were it should, fuel trims are a little bit more than I like to leave it (-12.1 at idle) but we were working on wot and cruising first. Shut car off, restart and its fine. Shut off and leave for a while, idles lean off the scale and you can't move the car. Finally something that has me stumped.
When I did the base tune on it, it was a complete cold start up. Let the car idle for about 30 minutes and it was fine. nothing is out of the ordinary in any of the ol tables around the temps where it starts doing that. oh and these are the only 2 cars I"ve ever run into this with both on zzp stage II cams (and thats with tuning 200+ cobalts)
Old Apr 21, 2013 | 09:58 AM
  #5648
advise's Avatar
Gunna look the car over today, change my o2 sensor and pull the battery and see how she acts from a dead cold start , Did 3 fuel trim resets lastnight at first that would make the car idle then the second reset didn't do anything
My brain hurts lol
Old Apr 21, 2013 | 11:39 AM
  #5649
100% METH's Avatar
Paul I'm seein the same issue while tuning rcorona8's car on zzp stg II cams
Everything works perfect
It randomly enters open loop at idle and goes rich.
Get back into part throttle/cruise and it goes back into closed loop.
Old Apr 21, 2013 | 12:29 PM
  #5650
Yeah my car used to do that random ol rich idle with the 272s but it was very random. This car just goes dumb lean but doesnt come out of it for some reason.
