Official TVS Thread!!!
#2256
Oh the pissing match ended on the last page. This is just mindless banter.
Plug 3 doesn't look so hot... others are pretty consistant. When will you be pulling the head?
#2258
In my search for pics a found this... And I'm sorry James, but that was a damn clever comeback! I lol'd so hard i pooped. Good thing I'm on the *******!
Ooooooooh.... A lot of these posts make more sense now. I didn't realize I missed that much in one day lol
My advice to you; get ahold of mrbelvedere. And if you're nice to him, I can 100% guarantee this will never happen again. That's all imma gonna say.
#2270
here is the deal the stock sleeves arent bad pieces but the main problem is when you replace them you get them in a finished bore and upon instalation(with the gm sleeve kit) they go out of round and to fix the problem you need to bore them. so what i decided was to get a stronger sleeve made that would handle alot more abuse then the stock sleeves would and they are .040 undersize so you can set the bore back to stock and it be round. now zzp has a great product and if you can afford a 1000+ for a block great or even more for dartons but if you cant whats left to do but get a different block or use gm sleeves. so the sleeves i had made are from ductile iron (not grey iron like the stockers) and have 2x the hardness and 2x tensill strength of the stock sleeves. some advantages is the strength better ring seal and less flex transmitted to the block due to the increased sleeve strength and less distortion due to heat. will these be as stout as a zzp block no they wont but for most of the people building ecotecs it should be more then sufficant.
#2271
i had already figured that was what happened but why did the hg let loose is what needs to be figured out and i may have your answer if you could post pics of the rest of the pistons
i have had custom sleeves made that fit in the stock hole that are better then the stockers and they will be available through me
