Oil Change information
Old Dec 26, 2005 | 02:06 AM
Mercury's Avatar
Alright, I have heard one thing or another about our oil. We are supposed to use Mobil 1 Synthetic correct? I heard if we don't we get in trouble with our dealership (Dare I say a warranty issue)
I need to change my oil badly. Exactally what model filter do I get and how much oil do I use? Thank you. I think we should make a sticky as of what our motor takes.
Old Dec 26, 2005 | 02:14 AM
retrop's Avatar
5 quarts of 5w30....not sure on the filter number.
Old Dec 26, 2005 | 02:21 AM
GotBoost?'s Avatar
Yeah i also have a question, i dont want to take my car to the dealer to get the oil changed because i dont want them to se my K&N CAI. So if i take it somewhere else, is Castrol Synthetic ok? I heard that your dealer cant say anyhting about you getting your oil changed somewhere else as long as you keep a reciept(proof) that you got your oil changed.
Old Dec 26, 2005 | 02:23 AM
retrop's Avatar
I would stick with the Mobil just to be safe buy yeah you can have the oil changed anywhere. I did mine myself and it was pretty easy, once you get to the filter cover nut.
Old Dec 26, 2005 | 05:52 AM
Malaclypse's Avatar
Mobil 1 synth in the factory reccomended weight (5w30). You'll need a 15mm to remove the drain plug and a 32mm socket to remove the filter. Easy as pie.
Old Dec 26, 2005 | 08:15 AM
denniss's Avatar
2.0 supercharged wants 6 quarts. Check your dealer for a filter, some parts are cheaper than you might think. I think the OEM filter comes with a new cap and gasket that you might not get with aftermarket filters.
Dennis
Old Dec 26, 2005 | 08:22 AM
Chevypowered's Avatar
The fram filter does not seem near as good as the on from GM. I did my oil on a sunday when the dealer was closed so I had to buy a fram. The one I took out looked like a much higher quality item than the fram in my opinion.
Old Dec 26, 2005 | 08:42 AM
myoshizawa819's Avatar
The 2L supercharged engine requires at least 6 quarts of Mobile 1 synthetic or any other synthetic that meets GM's GM4718M lubrication standard. Note you can put up to 7 quarts of oil into the engine without hurting anything. When I bought my car I noticed the oil level filled all 4 notches on the dip sick. When I did my first oil change I put the required 6 quarts in and was only filling the first 2 notches even after about 10 minutes of time to settle, it took another half quart to fill all 4. My local auto parts store sells Delco replacement filters with or without the plastic cap an O ring. I think I paid about $4.50US for a filter with no cap.
Old Dec 26, 2005 | 08:53 AM
Mrmaasta's Avatar
Aye 6 quarts! Have them fill out and sign/stamp your maintenance log book!
Old Feb 19, 2007 | 08:43 PM
DressBoyBlues's Avatar
i put 6 qts in mine and im still reading min so ill check in the morning and if its still low ill add a 1/2 qts but if anyone wants to know what filter acdelco is a pf456g for 05-06 and a pf457g for the 07
Old Feb 19, 2007 | 08:46 PM
GSoccer24's Avatar
6.5qts
Old Feb 19, 2007 | 10:18 PM
stealthy1ss's Avatar
Honestly I would stick with Mobil 1 Synthetic because it is a good oil. That is why gm recommends it. Remember you get what you pay for.
Old Feb 19, 2007 | 10:21 PM
jeremie's Avatar
you can use whatever oil you want. mobil 1 full synthetic is reccomended though. as for the filter, theres 2 styles for an ecotec filter.
you need the NEW STYLE it has a smaller hole in it than the old style. if you use the old style your engine will not build proper oil pressure and it could be damaged.
Old Feb 19, 2007 | 10:23 PM
rally's Avatar
wow...old thread revival?
Old Feb 19, 2007 | 11:14 PM
sunfirejoe's Avatar
yah holy ******* old
brandon04
Oct 21, 2015 07:04 AM
importkiller
Sep 30, 2015 07:18 PM
ashalle2
Sep 27, 2015 03:28 PM
roth
Sep 26, 2015 12:16 PM
