oil cooler help
oil cooler help
Alright I spun a rod bearing last year and im finally putting my engine back together. I dont wanna use it again in the fear of having metal shavings in it. Has anyone done anything with the oil cooler im not trying to spend 600+ dollars on a new one
Sorry for threadjacking op. Mrb, I thought the sleeve was in the block? The adapter appears to be sleeved...I'll find out soon enough I suppose lol
I'm sure you can back flush it with clean oil to clean any shavings out of it.
You don't need an oil cooler. You can bypass it. It's on there in case some knuckle head runs Dino oil in it. With the high temps needed to keep emissions low a cooler was needed and or synthetic oil. I never would never run the stock high temps so I ditched the cooler albeit the stock one was in the way and the decision to bypas was less trouble than a relocation. FWIW.
I extrapolated to be honest. The sad thing is that some engines like older V6 jeeps do not call for synthetic. When the oil gets a little too old and is burned off it cokes up in the oil passages.
importkiller
Sep 30, 2015 07:18 PM
