oil cooler help
Old Sep 26, 2014 | 08:20 PM
tdeschaine1022's Avatar
oil cooler help
Alright I spun a rod bearing last year and im finally putting my engine back together. I dont wanna use it again in the fear of having metal shavings in it. Has anyone done anything with the oil cooler im not trying to spend 600+ dollars on a new one
Old Sep 26, 2014 | 09:58 PM
ChrisR1S's Avatar
I'm tapping the adapter for mine to run a remote mounted cooler. I won't be using the actual factory cooler itself.. if you want it shoot me a PM
Old Sep 26, 2014 | 11:33 PM
mrbelvedere's Avatar
been there done it got the t shirt
you do not want to tap the oil cooler adapter get 2 weld on -10 bungs any line smaller then -10 will starve the engine of oil
Old Sep 28, 2014 | 07:35 AM
ChrisR1S's Avatar
Why not drill and tap? Drill the holes to 45/64 tthen run in a 1/2" NPT tap..similar has been done before with no reported issues..
Old Sep 28, 2014 | 08:15 AM
never seen or heard of someone doing that by doing that you risk the metal sleeve on the outlet getting twisted loose and causing problems
Old Sep 28, 2014 | 12:47 PM
ChrisR1S's Avatar
Sorry for threadjacking op. Mrb, I thought the sleeve was in the block? The adapter appears to be sleeved...I'll find out soon enough I suppose lol
Old Sep 28, 2014 | 12:50 PM
the sleeve is in the block
Old Sep 28, 2014 | 03:59 PM
insylem's Avatar
I'm sure you can back flush it with clean oil to clean any shavings out of it.
Old Sep 29, 2014 | 09:00 PM
Has anyone thought of tapping the oil bypass valve to 3/8npt and using a -10 an fitting?
Old Sep 30, 2014 | 07:05 AM
the oil bypass drops the oil back in the pan not to the engine and if it was a pressure source 3/8 npt is to small 1/2 minimum
Old Oct 28, 2014 | 11:12 PM
Stumpalump's Avatar
You don't need an oil cooler. You can bypass it. It's on there in case some knuckle head runs Dino oil in it. With the high temps needed to keep emissions low a cooler was needed and or synthetic oil. I never would never run the stock high temps so I ditched the cooler albeit the stock one was in the way and the decision to bypas was less trouble than a relocation. FWIW.
Old Oct 29, 2014 | 08:53 AM
it was not put on there incase some one ran dino oil and the ecotec engines were not designed to be run on any paticular oil the oil cooler was put on there to help the engine warm up faster and to try to control oil burn off both of whuch are emission related
Old Oct 29, 2014 | 10:08 AM
Stumpalump's Avatar
I extrapolated to be honest. The sad thing is that some engines like older V6 jeeps do not call for synthetic. When the oil gets a little too old and is burned off it cokes up in the oil passages.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
