Oil Leak... Ideas?
Old Apr 16, 2008 | 10:57 PM
bgbearcatfan's Avatar
Oil Leak... Ideas?
So as the title says, i apparently have an oil leak coming from the side of the engine. I noticed it a couple weeks back so i wiped the area clean, and now oil is collecting again. I know I know, im taking it in for warranty work obviously, just curious if anyone has had a similar problem or ideas of what it might be. Here's a picture of what im talking about.
Sorry for the crappy picture.
And btw, the only real work i had done on it was stage 2.
Old Apr 16, 2008 | 10:58 PM
Dead Zen's Avatar
weird. i would expect that maybe if you had the valve cover off
Old Apr 16, 2008 | 10:59 PM
Frankruffolo257's Avatar
it could be the valve cover or you might have a pourus head.
Old Apr 16, 2008 | 11:01 PM
i have no idea where the injectors are, but could it be the mechanic did tighten something up well enough when doing the stage 2 upgrade?
so if you think it was the valve cover, just trying tightening up the bolts on the side there?
Last edited by bgbearcatfan; Apr 16, 2008 at 11:01 PM. Reason: Automerged Doublepost
Old Apr 16, 2008 | 11:07 PM
there is no need to remove valve cover to install injectors. they are on the outside.
Old Apr 16, 2008 | 11:11 PM
well that answers that question
Could it be just the seal that the valve cover pushes down on is bad?
Last edited by bgbearcatfan; Apr 16, 2008 at 11:11 PM. Reason: Automerged Doublepost
outtamymind's Avatar
how many miles are on your car. and it could just be one of those things that just happens. i've worked on a car that had like a 1000km on it and had a pretty bad oil leak on it.
Old Apr 16, 2008 | 11:16 PM
its a 2007, with about 10,500 miles on it
Old Apr 16, 2008 | 11:26 PM
spd4lifess/sc07's Avatar
ive noticed the same thing with my 07 in about the same areas..... my guess is the valve cover as well...
Old Apr 16, 2008 | 11:30 PM
well im calling them tomorrow to schedule a time, so ill let you guys know what they say. thanks for the replies guys
Old Apr 17, 2008 | 05:55 AM
stavros's Avatar
yeah brian... make sure you tell them that your valve cover gasket is seeping oil ever since you have hat stg 2 done.... thats kinda odd that happened with only 10,500. dont let them fool you, that will be covered under warranty
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
Rduncanss06
Sep 27, 2015 11:17 PM
