Oil Pump Gear Failure
I will be building a 7,500rpm build soon and was curious about others who have similar redlines. GM recommends the hardened oil pump gears for higher or sustained time at the rev limiter, but i have only heard of one member's oil pump gear failing on him. Is this a excessively safe part to have? or do most people recommend them?
Also, i might as well ask this as well. I'm getting a set of weisco pistons, and i already have some eagle rods. Are new main/rod bearings needed for installation? Or do most members just re-use the stock ones? I'm looking for around a 400whp build, 450whp tops.
anyone else have this failure?
ok. good to know. I was just looking at TTR and other vendors, and all the clevite bearings were in the hundreds of dollars... I didnt know new OEMs were so cheap. Are the clevite ones supposed to be that much stronger?
Got a part number? I can get it cheaper if I have a part number. I have access to many of GM's suppliers. For example, Carter is GM's supplier for fuel pumps.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
roth
Sep 26, 2015 12:16 PM
