Oil weight
Old Aug 7, 2007 | 10:23 AM
Hokage's Avatar
Oil weight
Instead os using Mobil 1 5w-30 I used Mobil 1 10w-30 weight oil. Mainly, becuase I moved to Las Vegas and I wanted extra protection from the heat. Would this be an issue with warranty or cause engine damage?
Old Aug 7, 2007 | 01:38 PM
JMH's Avatar
JMH
It's just taking your oil longer to circulate through the engine at start-up.
I wouldn't use it.
Old Aug 7, 2007 | 03:44 PM
SCcobaltSS's Avatar
Its warrentied right? Use what recommended for the car, if it breaks or ceases from the extra heat....... they'll fix it for free..
Plus man, I live in Arizona and we hit 115+ days. You have nothing to worry about.
Old Aug 9, 2007 | 11:33 PM
rnjmur's Avatar
All I can say is read the owners manual it will tell you all you need to know. The owner's manual specifically says DO NOT USE ANY OTHER OIL BUT 5W-30. I'm sure you could use a thicker oil in hotter weather and be ok, but when it comes to warranty issues the manual is the bible.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
