Okay idk about this but
Old Aug 14, 2008 | 10:35 PM
shsballa023's Avatar
Is there any way to get my stock boost gauge to have a blue light instead of how it is now? I don't really want to buy a new one or anything just seeing if there is anyway to switch out the lights to like a led or something.
Anyone???
Last edited by shsballa023; Aug 14, 2008 at 10:35 PM. Reason: Automerged Doublepost
Old Aug 14, 2008 | 10:45 PM
domin8_gt's Avatar
IMHO, I'd rather buy the Cobalt series one to replace the OEM gauge. It lights up in blue.
Old Aug 14, 2008 | 10:51 PM
rrutter81's Avatar
go white
supposedly you can crack open the front of the gauge plate but ive never tried....either way you will have to soder the LED in there if your hellbent on keeping it....
and your cluster wont match
Old Aug 14, 2008 | 10:54 PM
You must not have seen my cluster....
Old Aug 14, 2008 | 11:09 PM
rrutter81's Avatar
give it a shot then.... ill crack open my stock gauge for you if you want
Old Aug 14, 2008 | 11:10 PM
If you really want to and see if its possible to get a blue led in there for me that would be awesome man. But if you don't wanna i don't blame ya
Old Aug 14, 2008 | 11:13 PM
mrbelvedere's Avatar
how can i get dash lights like that
Old Aug 14, 2008 | 11:21 PM
blackcatcustoms.com
Old Aug 14, 2008 | 11:23 PM
an0malous's Avatar
Old Aug 14, 2008 | 11:24 PM
Thats not your stock boost gauge tho. I'm wanting to make my stock one look like that tho.
Old Aug 14, 2008 | 11:28 PM
rrutter81's Avatar
ok dude i opened it up... took about 5 minutes.... and ill tell u what u have to do to avoid ******* it up like i did
blackcatcustoms.com
i soldered my own LEDs in
Old Aug 14, 2008 | 11:29 PM
an0malous's Avatar
ummm yes it is
Old Aug 14, 2008 | 11:32 PM
The led's were also soldered in mine. but notice how mine has the logo and ****. plus its a white face with blue numbers and the logo
Originally Posted by an0malous
ummm yes it is
Really? Lol, i didn't know it went up to like 140. Hmm shows how much i pay attention
So how'd you do it an0malous
Ahhhh yours isn't in psi
Last edited by shsballa023; Aug 14, 2008 at 11:32 PM. Reason: Automerged Doublepost
Old Aug 14, 2008 | 11:33 PM
scampbell's Avatar
ummm yes it is
you see he is from this place called canada....somewhere up north i hear... but anyway they use different measurements for their boost and speed, etc
Old Aug 14, 2008 | 11:34 PM
rrutter81's Avatar
ok first step.... remove the pillar (im assuming you know how to unbolt the screw)
unclip the boost gauge (duur)
pull out the boost gauge and have the gauge's ass end (where the wires stick out) facing you.
Now use a flathead screw driver and VERY CAREFULLY slip it under the chrome bezel
twist the screw driver about 45 degrees prying the "lip" of the bezel up all the way around until it comes loose.
Now using the same screwdriver pop the gauge reading (the one with the numbers of boost) IN to the gauge so you have better access to the needle.
Pull the needle off (carefully)
Pull the gauge face off (one with numbers)
you will see 2 squares near the center of the needle. You have plenty of room to solder in a big ass LED light.
As far as boost calibration goes vs cluster, i suggest you plug it in after you solder the LED light where one of those squares goes and see if it is calibrated correctly by putting the ignition in the forward position without starting it. It should read 0
When it is calibrated just slap on the chrome bezel and use the flathead to tap it in tight
there ya go!
Old Aug 14, 2008 | 11:37 PM
way to be an ass when i posted before you that i noticed his isn't in psi
rrutter81's Avatar
yes i know you went with blackcatcustoms, and i might as well since i couldnt scratch off the BIG ticks on my speedometer and rpm monitor.
Old Aug 14, 2008 | 11:41 PM
scampbell's Avatar
damn i was watchin pinks....now i feel like a dummy not
Old Aug 14, 2008 | 11:42 PM
Scampbell you are no use in this thread so just stay out and go be a dick somewhere else
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 29, 2015 11:07 PM
jmelton327
Sep 26, 2015 10:04 PM
