opt b w/o dual pass
Old Mar 25, 2010 | 06:11 PM
MP Cobalt's Avatar
opt b w/o dual pass
I have no idea how to set it up without having the dualpass endplate. Has anyone done this it without have dual pass if so give me some info because I'm lost.
Old Mar 25, 2010 | 06:25 PM
Pyros777's Avatar
I would add a Y splitter right between the pump outlet and heat exchanger inlet. Inlet being the one on the passenger side of the vehicle. You'll have to cut some hose to make room for the Y connector.
Run a 3/4" hose from the outlet of the opt. B tank to the remaining part of the Y connector.
Run the 1/4" hose from the small connector of the opt. b tank to your bleeder valve on top of your stock h/e using a 1/4" brass fitting.
So...
One of these:
http://www.crateenginedepot.com/stor...P1720C221.aspx
One of these:
http://www.crateenginedepot.com/stor...P1693C221.aspx
Some of these (or home made):
http://www.ottperformance.com/store/...ets-11p160.htm
Some 3/4" hose, some 1/4" hose, and a few hose clamps, plus whatever connectors you feel you need to get from point a to point b.
Basically you'll still have your stock reservoir attached to the front of the supercharger, PLUS the opt. b tank.
Should definitely help in bleeding the coolant system when adding an aftermarket heat exchanger, plus whatever small help the extra coolant volume provides.
Old Mar 25, 2010 | 06:27 PM
shroogis's Avatar
I've tried this...Check out my old thread
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/option-b-no-dual-pass-182975/
From what I can tell, you want the coolant to enter the front mount heat exchanger in the bottom, and exit in the top, that way the coolant flow and the air are both going up, instead of the coolant flowing down and the air trying to escape up.
Old Mar 25, 2010 | 06:28 PM
ItalianJoe1's Avatar
it's not option B without the endplate, just a larger tank. Why don't you have a dual-pass plate?
Old Mar 25, 2010 | 06:31 PM
shroogis's Avatar
I agree, leave the factory T, it might help. I never tried the T and option B with no dual pass.
Old Mar 25, 2010 | 06:51 PM
MP Cobalt's Avatar
I never got one. lol so option b is pointless without the dualpass endplate?
Old Mar 25, 2010 | 06:54 PM
shroogis's Avatar
Ehh, I wouldn't say useless. It does increase the coolant capacity of the intercooler system, but teaming it with a dual pass endplate is the most effective
See if ItalianJoe can make you one. I have one of his and it's fantastic
Old Mar 25, 2010 | 07:00 PM
Pyros777's Avatar
^ same here.
Old Mar 25, 2010 | 07:01 PM
MP Cobalt's Avatar
Yeah i might have to. I checked out your thread. so you put a T in the line going to the stock h/e from the enplate?
Old Mar 25, 2010 | 07:06 PM
shroogis's Avatar
Yep, the T is required to run a 3/4" line to the opt b tank.
Old Mar 25, 2010 | 07:07 PM
MP Cobalt's Avatar
could you draw me a diagram on exactly how you saying so when i do this i don't get confused.
Old Mar 25, 2010 | 07:09 PM
shroogis's Avatar
There is a diagram in the post I linked Trying to do exactly what you're doing, but I don't recommend it without a dual pass endplate, I had horrible luck doing that.
Old Mar 25, 2010 | 07:11 PM
MP Cobalt's Avatar
So your recommending waiting until I get dual pass?
Old Mar 25, 2010 | 07:13 PM
shroogis's Avatar
Yes, highly. I gave up and put the factory T back in until I got a dual pass. Once I did the dual pass and hooked my opt b tank back up, it's golden.
Old Mar 25, 2010 | 07:15 PM
MP Cobalt's Avatar
you mean the fill cap t? so when i get dual pass or just get rid of the option b since i have meth injection.
but when dp is installed that t gets takin out?
Old Mar 25, 2010 | 07:50 PM
shroogis's Avatar
Yep, you get rid of the factory T when you have dual pass and option B.
Old Mar 25, 2010 | 08:04 PM
MP Cobalt's Avatar
damn that looks complicated. where you fill it up then? in either of the big tanks i guess
Old Mar 25, 2010 | 08:18 PM
shroogis's Avatar
Yeah, it looks complicated, but once you get a dual pass, i'll help ya.
There's only 1 tank for the intercooling system, which is the Option B tank. That's what you fill up.
Old Mar 25, 2010 | 08:36 PM
Originally Posted by Pyros777
^ same here.
I had like a proud father moment, two of my customers educating someone on how to do it right Makes me so happy.
OP, I have another plate ready (actually Nate's old core), so if you are ready, it's ready to go. PM me if interested.
Old Mar 25, 2010 | 08:37 PM
qwikredline's Avatar
it is so easy. put an upside down T in place of the silly little Rervoir. take a hose from the top of the t to the new reservoir (option B) then run a small 5./16 id hose with .040 restrictor to the top of the stock HE. Redlines need a 1/4 barb 1/8 npt 90 degree fitting, Cobalts a straight. I can post a fancy diagram later. The stock system cant keep the air out. The Option B does, and therefore the system will work as it was intended, which it generally does not stock. I ran just this for 2 years. It was uncomplicated and worked great. OTTP have all the parts you need and it is not expensive. Diagram later...
Old Mar 25, 2010 | 08:43 PM
Exactly right, although for most people it doesn't seem to be that simple John. Gotta remember, not everyone has done this kind of work before.
I've walked people through it over the phone before though, it's not as hard as it seems with a little guidance. I can also supply the necessary bleeder fittings for the top of the stock H/E if needed, I can get them the same place I get the big fitting for the endplate. Straight or 90 degree, 1/8npt to 1/4" hose is what I had luck with.
Old Mar 25, 2010 | 08:58 PM
MP Cobalt's Avatar
When you take that cap off the stock h/e theres like a blueish seal or something what you do leave it alone and just put the fitting on it?
Old Mar 25, 2010 | 09:11 PM
a pipe thread is a tapered hole with a thread. The blueish stuff is pipestick or teflon tape, YOu wrap the tap or put the pipestick (a white paste) on the threads and then gently tighten it, not so it locks or it will pull out the threads in the alloy he they are fragile. Thats why the pipestick or teflon tape to make it snug in the threads but leak proof. Ital Joe can help you he is a good man.
Old Mar 25, 2010 | 09:46 PM
Some sort of pipe thread sealant (teflon tape or liquid stuff works fine), nothing special.
Old Mar 26, 2010 | 07:39 AM
Staged07SS's Avatar
Administrator
Administrator
Now that is a nice diagram .... people shouldn't have anymore questions on installing an Opt. B tank or Opt. B tank w/ dual pass. Nice post qwikredline
Jan 12, 2016 12:01 AM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
