Option B.
Old Jul 3, 2008 | 07:52 PM
Zach06CobaltSC's Avatar
Option B.
Hey guys, my shop installed my option b incorrectly. I can't specifically say how they did, but I can tell you this. I have a large hose running Across my engine bay from the left to the right, above my radiator hose to the other side and it goes back down. I know for a fact the hose is NOT supposed to be routed like this.
I was wondering if anyone knew where I could get instructions online for the option b kit, so I can show my mech what to do specifically.
Old Jul 3, 2008 | 08:03 PM
brett5's Avatar
can't you just move the hose...it's still connected to what its suppose to be connected too
Old Jul 3, 2008 | 08:21 PM
I don't know if its actually connected to what it is supposed to be though. I paid the shop to do a job for me, they did it incorrectly, because i provided instructions for them to follow, so now they need to redo the work and do it correctly.
Which they will without any issue. I just need to get the instructions again online to show them where they go.
Old Jul 3, 2008 | 08:34 PM
brett5's Avatar
oh i see did you chechk the how to on here i think there is one for optoin b if i'm correct
Old Jul 3, 2008 | 09:31 PM
theneelster's Avatar
crate engine depot has the diags...
Old Jul 3, 2008 | 09:46 PM
Doc's Avatar
Doc
take a pic and upload it...that'd be very helpful.
Old Jul 3, 2008 | 09:51 PM
qwikredline's Avatar
the hardest part of the install is popping out the laminova tubes and switching them. Not that it is that hard, but its tricky. THe inlet manifold(Laminova intergrated into this) is held by bolts and studs, which you can see and a gtricky bolt underneath that you cannot (15 mm head on bolt) There is a an external torx socket that can undo and remove the two inlet manifold studs (use blue locktite when replacing them) this you can release the inlet manifold assembly up and out without too much drama, then once you have the manifold out you can swap out the laminova cores (tubes) and install your new face plate.
I tried to copy the plumbing diagram and cant, pm me with an email address and i can send you the complete plumbing diagrams good luck
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
