option b/dual pass?
Old Apr 5, 2011 | 09:33 PM
joeyfingers's Avatar
option b/dual pass?
so im fairly new with the ss and i hear alot about the option b and the dual pass endplate.so iam wondering what are they?what do they do?how hard are they to install? and for the record i have the zzp stage 1 heat exchanger on the car.
Old Apr 5, 2011 | 09:36 PM
heathkidder's Avatar
dual pass alows you to run 2 h/e cooling mods pretty much its alot better than stock if were running small pulleys and bigger injectors.
its all pretty much to do with cooling
Old Apr 5, 2011 | 09:38 PM
ya im running zzp stage 2 kit on my car right now.how hard is it to install?
Old Apr 5, 2011 | 09:39 PM
option b is cake never installed dual pass to be honest.
Old Apr 5, 2011 | 09:40 PM
so option b would be my best bet in your opinion?
Old Apr 5, 2011 | 09:42 PM
https://www.cobaltss.net/forums/2-2l...-2l-g5-219119/
there is the diagrams of it
Last edited by heathkidder; Apr 5, 2011 at 09:42 PM. Reason: Automerged Doublepost
Old Apr 5, 2011 | 09:45 PM
yellow dragon's Avatar
The dual pass. I helped a buddy install it's not to hard but does lean towards being a pain you have to take off the S/C and the intake manifold and there is one bolt that is a ***** ended up removing the alternator to get a half inch of extra space. Check the how to section there is stuff there on how to do it.
Old Apr 5, 2011 | 09:46 PM
Sylver01's Avatar
the dualpass refers to the endplate. the cooled coolant only passes through the laminova cores twice. you can run the option b and dual pass endplate with the stock h/e if you like.
The dual pass endplate was a bit of a pain since taking the supercharger and everything out. the endplate itself is only 5 bolts I think.
It's just tedious and time consuming taking everything off and making sure you get it all back on
Old Apr 5, 2011 | 09:47 PM
what is going to give me better gains though option b or dual pass?
Old Apr 5, 2011 | 09:52 PM
Sylver01's Avatar
option b just allows a little more coolant to be held in the system as opposed to the little filler neck.
The dual pass endplate cools the compressed air and allows for a better burn of the fuel for more power. I did both at the same time since i added a second heat exchanger and was gonna have the front end ripped apart in the first place
Old Apr 5, 2011 | 09:53 PM
and can i just run option b without the dual pass endplate?i do have thee zzp stage 1 h/e on the car
Old Apr 5, 2011 | 09:56 PM
Sylver01's Avatar
ya you can. the option b is just a larger coolant tank for the intake air cooling system. Normally when someone does the dual pass they do the option b as well. It also makes bleeding the system of air alot easier.
Had all the air out of my system in about a day or so
Old Apr 5, 2011 | 09:59 PM
is it worth it to do just the option b are there any gains that would be noticeable?the reason im asking this is because i plan on gettting the car tuned in a month or so and i want to get the best numbers i can.
xnigelx's Avatar
thee is tons of info on this topic, my reccomendation is a flothru option b.. it atully adds more fluid to the system. google vulcan turbo or something and they have a link on thier site for cooling mods. definately get an optionb
Old Apr 5, 2011 | 10:02 PM
Sylver01's Avatar
if that's the case then get the option b with the dual pass. you will notice a bit of a difference once installed and bled of air
Old Apr 5, 2011 | 10:06 PM
i would do both
Old Apr 5, 2011 | 11:26 PM
redcobalt07's Avatar
I just made a thread for info about the dual pass.
Old Apr 6, 2011 | 12:30 AM
xnigelx's Avatar
yeah i wasnt payiong attention too much when i was typing.. but yea do both at the same time. like everyone else said
Jan 12, 2016 12:01 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
goaliemo
Sep 28, 2015 01:37 PM
