Option B help
Old Aug 21, 2012 | 02:31 PM
08baltls's Avatar
Option B help
Ive searched and haven't found an answer to my specific problem in past threads.
I'm looking to install option b on my car and I've seen that I need an air bleed line running from my heat exchanger to the reservoir. My problem is, my bleed location is more like a drain. On the bottom driver side of my heat exchanger there is a petcock which to me seems to be a drain instead of a bleeder. It's an AFCO front mount heat exchanger from what I can tell.
So how would I go about hooking up Option B? I'm a bit confused.
Old Aug 21, 2012 | 02:53 PM
TStone's Avatar
Does the AFCO replace your stock one? Because I have the ZZP FMH/E and the stock one, and my bleeder line goes to the top of my stock H/E
Old Aug 21, 2012 | 03:13 PM
Melon's Avatar
Same here. Top passenger side if I remember correctly
Old Aug 21, 2012 | 03:17 PM
TStone's Avatar
^ yes
Old Aug 21, 2012 | 03:54 PM
08baltls's Avatar
Yeah I'm AFCO only with no stock h/e.
Old Aug 21, 2012 | 04:26 PM
07darknight's Avatar
I ran into the same problem when I installed the option b And zzp heat exchanger on my 2.2 and I thought that I had all the air out for a couple hours until I unbolted the option b and lifted it off the bracket to make sure that it was the highest point and lowered my hose a little and I lost about half coolant that was in there so there was a huge air pocket filled up and everything has been good for couple months hope this helps
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
