Option B Issues
Old May 31, 2008 | 03:01 PM
godsfshrmn's Avatar
Option B Issues
I recently did the Option A upgrade and was not making hardly any boost and noticed a lot of circulating air bubbles. There was obviously no way to get these out so I went ahead and did option B. My car is still riding the same for some reason. The air should have been bled out by now. Sometimes I can make up to 16psi but most of the time it is 9psi. When I punch it, it never gets up and goes like it used to. The boost builds but it eventually goes. I hear a strange hiss when I'm in boost also, probably from the boost bypass? I doubt I have a leak anywhere because the max boost is always 9 or 16psi.
Anyone have any ideas?
edit: the flow into the extra overflow tank is pretty strong and burp free.
Old Jun 2, 2008 | 12:25 PM
godsfshrmn's Avatar
Anyone have any ideas? I keep throwing a knock sensor code also...I'm betting its bad
Is this the knock sensor? I remember where the end with the hole is located but I don't think i ever saw the other end. Where does that plug into?
Old Jun 2, 2008 | 01:16 PM
LopsidedJester's Avatar
are you throwing any codes? it should be giving you codes if its acting that funny. Maybe you have a manifold leak somewhere causing you to go too rich and lose power? Did you replace your intake manifold gasket after the install?
Its also probably best if you had a gauge that could see all this happen, i bought an Aeroforce Interceptor to watch the IAT2 after the dual pass install and also watch for knock retard.
Old Jun 2, 2008 | 01:20 PM
lsjwannabe's Avatar
check all your gaskets
Old Jun 2, 2008 | 02:25 PM
godsfshrmn's Avatar
I'm betting its the knock sensor. I thought that was a ground for some reason and didn't tighten it back to spec.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/getting-knock-sensor-115114/
Old Jun 2, 2008 | 07:45 PM
XbandiniX's Avatar
Having air in ur system has nothing to do with losing boost.. You probably have a boost leak somewhere. Check all of your lines. And if you did install the option b correctly the air should bleed out eventually anyway.
Old Jun 2, 2008 | 08:27 PM
godsfshrmn's Avatar
Yea I know that. I figured the ecu could be bleeding off boost for added KR. Im going to pull it apart tomorrow and check the sensor.
Old Jun 2, 2008 | 09:27 PM
Tennpenn83's Avatar
switching from option A to B does not have any thing to do with where you may be losing boost. IF it's not the knock sensor being unplugged, i would bet that there is a problem with the seal on the endplate or with the laminova coils or a combination of both
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
