Ordered cams finally!!!
I noticed the 8760 grind number on the cam in your pic. I'm guessing you have this set listed on ecotecpower dot com:
Street /Strip 113300 set 113301 INT/113302 EXH ) GRIND # ECO XE258HR-11
Grind Specs 8760/8761 HR111
INT
Max Gross Lift: .440
Cam Lobe Lift: .260
Advertised Duration: 258
Duration @ 0.50 Valve Lift: 216
Valve Timing @
0.50 Valve Lift: BTDC: -2
BBDC: 41
EXH
Max Gross Lift: .436
Cam Lobe Lift: 258
Advertised Duration: 262
Duration @ 0.50 Valve Lift: 218
Valve Timing @
0.50 Valve Lift: ATDC: -3
ABDC: 38
These specs are for the cams installed at the following maximum lift centerlines: INT:110 EXH: 112
INT
Cam Lobe Lift: .260
Valve Timing @
BBDC: 41
EXH
Cam Lobe Lift: 258
Valve Timing @
ABDC: 38
INT
Cam Lobe Lift: .260
Valve Timing @
BBDC: 41
EXH
Cam Lobe Lift: 258
Valve Timing @
ABDC: 38
INT
Cam Lobe Lift: .260
Valve Timing @
BBDC: 41
EXH
Cam Lobe Lift: 258
Valve Timing @
ABDC: 38
Last edited by SuperSport4; Jun 20, 2010 at 04:36 PM. Reason: Automerged Doublepost
then he has another much bigger full machine shop nearby in Costa Mesa as well.
honestly Ray is like the worst ever at replying to email if he ever replies.
His best contact is his cell # 714-612-3639 and he will accept business related calls on it, if he dont answer just make sure you leave a message he'll listen and call right back lol.
His shop # 714-545-0159 but he rarely answers it and if someone does its his son who will get you to him (usually by cell) thats why i say just call his cell.
To give you what you actually asked for, here is his contact info on his website.
http://www.batesengineering.info/contact.htm
here is where you can see some of his products he offers.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
