Over fueling problem
Old Jul 4, 2011 | 03:53 PM
cottrezee's Avatar
Hi all, I'm having quite the issue, my clutch went in my 07 ss. So I dropped the cradle this past winter to do the repair. While it was out I got my head p&p'd, went down to a 2.7 pully and some 60's with some meth. I got the ZZP canned tune ECU just to get me on the road before I could get to the dyno. But, Now when I try to start it it turns over and wants to fire for a couple seconds then just turns over because the plugs are so fowled with fuel. I called ZZP, they did say it is possible that the ecu could have gotten flashed wrong and I could send it back to get reflashed. But I wanted to see if you guys had any opinions on what it could be first. Electrical connection problem? Anything else?
Thanks guys, I havent drove my baby in almost a year and its startin to kill me!
Old Jul 7, 2011 | 03:18 PM
cottrezee's Avatar
Bump!
Old Jul 7, 2011 | 03:29 PM
SCcobaltSS's Avatar
Well if the tune has the wrong size injectors then it could definately be over fueling. Where do you live? Have someone with HPT pull the tune and check it out. If they see something wrong work out a deal for a custom tune.
Old Jul 7, 2011 | 05:26 PM
mrbelvedere's Avatar
send it back let zzp fix the problem
Old Jul 7, 2011 | 05:27 PM
Chevycobaltss3's Avatar
Yeah if you paid cash for the tune send the pcm back to zzp!!Or a custom tune!! Verify the injectors are correct as well!
Old Jul 10, 2011 | 04:47 PM
cottrezee's Avatar
I'm in southern Alberta to my knowledge there isn't any hp tuners around here. Sounds like I'll just send the ecu back and see if that helps out. Thanks guys!
Old Jul 10, 2011 | 05:40 PM
383_Stroker's Avatar
If the cams are out of time, it can have similar symptoms to that
Old Jul 11, 2011 | 12:22 PM
cottrezee's Avatar
The cams are in time. They originally werent and when I stopped cranking it it would backfire so loud it sounded like it was gunna blow the exhaust off. That's fixed and the backfire is gone
Old Jul 11, 2011 | 12:23 PM
cottrezee's Avatar
Is it possible that the machine shop that did the porting and polishing put the cams in wrong? Intake on exhaust side and exhaust on intake side?
Old Jul 11, 2011 | 01:03 PM
i dont think the engine would make a complete revolution with the cams like because of the cam timing would be so far off the valves would hit the pistons
Old Jul 12, 2011 | 05:29 PM
cottrezee's Avatar
Well, I put in my 42 pounders and my gms2 PCM and the same problem is still happening. Ripped it apart to check the cam timing for the 3rd time and it's perfect. But, I found a broken ground. So I repaired it and same problem. Now, what I'm thinking cause I tried to start it with the broken ground on both pcm's. Could it have maybe fried both pcm's because of the broken ground? Or any other ideas?
Old Jul 12, 2011 | 08:48 PM
maybe you need to just retune it i had a simular problem and i ended up retuning to fix it
Old Jul 12, 2011 | 09:49 PM
cottrezee's Avatar
The gms2 worked perfectly fine when it came out
Old Jul 13, 2011 | 08:26 PM
cottrezee's Avatar
I got all the wiring/vacuum line diagrams from all data and everything is perfectly right. I'm out of ideas
Old Jul 15, 2011 | 03:28 PM
cottrezee's Avatar
Bump!
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
