P0171 (Searched for an hour, still confused)
Ok so my car is throwing P0171, unmetered air, running lean and what not.
From searching, Ive seen that some people think its the solenoid, others think its the bypass valve...
My question is how do I test them to see if they're bad.
My cars symptoms are the car runs sluggish, horrible gas mileage, and I already checked around for leaks. Both o2 sensors are new and the MAF is working fine.
Thanks in advance for the help
When I was getting 0171, I had to take a can of carb cleaner and spray around the engine bay and listen for a change in RPM. Turns out the compressing of the phenolic spacer I put in caused unmetered air to enter at where the IM met the engine block. Spray around the vacuum hoses and near the gaskets.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Delta coupe
Sep 30, 2015 08:11 AM
